Old 11-28-2007, 05:45 PM
forcefan97 forcefan97 is offline
01 honda civic timing belt replaced no start
On a 01 Honda Civic w/ 260 k miles , timing belt broke. Installed nu belt and aligned timing marks. Engine wont fire up & theres spark and injection. Any thoughts ?
Old 11-28-2007, 05:49 PM
inafogg inafogg is offline
Re: 01 honda civic timing belt replaced no start
hello have you done a compression test
Old 11-28-2007, 06:52 PM
yes i have & there is zero compression on all 4 cyl..
Old 11-28-2007, 08:24 PM
UncleBob UncleBob is offline
AF -Advisor
either the timing is off, or you bent valves on all of the cylinders. The latter is likely regardless to the former, unfortunately. Honda's almost never survive a broken belt
life begins at 10psi of boost
Three turbo'd motorcycles and counting.
Old 11-29-2007, 02:09 AM
curtis73's Avatar
curtis73 curtis73 is offline
Professional Ninja Killer
what happened is that the valves stopped but the engine didn't. The pistons slammed into the valves and bent/destroyed them.
If you're lucky you just need new valves in a rebuilt head. If you're not lucky, you need pistons, rods, valves, and a host of other stuff. Sorry for the bad news, but I think you'll find that its not pretty in there.
Dragging people kicking and screaming into the enlightenment.
Old 11-29-2007, 07:28 AM
Thanks for the reply. The timing marks are dead nuts.Ill remove the head and see whats up.
Old 11-29-2007, 07:30 AM
Well , dudes the head is off and no signs of holes in the pistons. I did notice on 1 of the cyl on the head that both intake & exhaust valves were open at the same time.
Old 11-29-2007, 11:27 AM
curtis73's Avatar
That is probably normal. The cam is designed with overlap. The intake valve is supposed to start opening before the exhaust valve completely shuts.
It doesn't take much bend to make a valve not seal. Its good to hear that things aren't completely munched. The last Honda I repaired we just ended up putting a rebuilt engine it was so bad.
Old 11-29-2007, 11:37 AM
The cam is off the head and i noticed that some of the valves arent shut . The head is at a head shop .
Old 11-29-2007, 12:41 PM
curtis73's Avatar
Sounds like you got lucky. Congrats. Keep us updated!
Old 11-29-2007, 12:59 PM
Rodger Dodger ! Thanks for the help .
Old 11-29-2007, 01:12 PM
hello before you go & put any $$ in the head.keep in mind that the valve job your going to need is going to seal the upper end of the engine.now with the miles on engine its going to put more stress on the lower end.you will probolly start seeing alot more oil usage being the rings ect. are all high mileage.its not always the case but some thing to expect.good luck
Old 11-29-2007, 01:56 PM
Good point! Might as well get a used engine . The top end is rebuilt , but the lower end is not.
Old 11-29-2007, 03:21 PM
AF -Advisor
I wouldn't pre-emptively put a motor in it.
if it ain't broke, dont' fix it!
honda's are some of the best engines out there. It might be tired, but that doesn't mean its *needed*
Old 11-29-2007, 05:16 PM
Hondas are pretty good cars , wish they had timing chains. Well the shop found some worn out and damaged valves & some other stuff , so the head is getting rebuilt. Lesson to be learned , change the timing belt every 90/ 100k .
