Old 11-25-2007, 03:21 PM
offroader2000 offroader2000 is offline
how do u know if your 4x4 really works???
what would be a true test to see if your 4x4 be it 4 hi or low is really working.would it be to jack all 4 tires off the ground put it in 4 hi give it gas and see if all wheells are spinning????cheers.
Old 11-26-2007, 03:20 AM
DelCoch's Avatar
DelCoch DelCoch is offline
Re: how do u know if your 4x4 really works???
Check out this post.
Old 11-26-2007, 08:57 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
As Delcoch pointed out read that post and do some searching.
The old crow hop test. Is a fast and easy way to check it.
Drop it in real 4W high or 4W low and make a sharp turn on dry payment.
If you have a crow hop or 4W bind up it is working.
MT
MT
Old 11-27-2007, 04:04 PM
534BC 534BC is offline
Do a burnout on a stone driveway or road.
Old 11-27-2007, 05:10 PM
Juiced383's Avatar
Juiced383 Juiced383 is offline
The easiest way is to put your front tires on a tall curb, put it in 4wd and see if the truck struggles to get up the curb. Do a comparison against 2wd to see if there's a difference
