Go Back   Automotive Forums Car Chat > Nissan > Primera | G20 > Maintenance
Maintenance problems, fixes.
Old 09-24-2001, 02:44 PM
rickp rickp is offline
Question tire wear
My driver side front tire has been wearing on the outer rim for a good while (almost since car was new). What kind of alignment adjustment or repair is needed?
Old 09-24-2001, 06:50 PM
dre dre is offline
it could just be underinflated....
i always get this stuff confused, but also my be the toe-in is too much...might need more toe-out.
Old 09-24-2001, 10:57 PM
kenchan's Avatar
kenchan kenchan is offline
your taking your right hand turns too fast and too much. rotate them more frequently. check tire pressure every 3 weeks.
1998 Prelude SS - TEIN HA with upper pillows, SSR Integrals 17x7 with SP8000 (215/45), GReddy Evo catback, Iceman Comp Intake, DC Sports header, Apexi VAFC, ZEX 55 shot with bottle heater, NOS blanket, Factory Body Kit, Spoon F/R tower bars, JDM Foglamps, Carbon Fiber trim, Razo pedals &knobs, Fiamm Dual air horn
Future Mods: Lighten car, 2nd 10lbs nitrous bottle would be nice too.
2001 G20 P11 AT- TEIN NA, TRM Snipers 17x7 with Potenza RE910 (215/45), Arospeed Dual-outlet Muffler, K&N Drop-in Airfilter, WW Front Lip, Nakamichi MB75 1DIN 6CD Changer/Receiver, FIAMM Dual Air horns, Levoc Pedals, PIAA (H4 Superwhite H3 Ion Crystal, 168 SuperWhite)
2002 WRX MT- TEIN HA's with upper pillow mounts, 1000Miglia HT3 17x7 with sumitomo HTR+ 225/45/17, painted side skirts, Cusco front & rear strut bar, Whiteline rear swaybar, aluminum endlinks, Blitz NUR Catback, HKS seq. BOV, factory front lip, rear valance, Kartboy short shifter and bushings.
Future mods: dressup wheels with Potenza S03 225/45/17 tires, TurboXS UTec, maybe an uppipe. by then, it'll be fast enough.
fiamm dual air horns.
Old 09-25-2001, 05:37 AM
primera man's Avatar
"P-Man"
Take your car to a good wheel alignment centre to get it set up correctly.
Check the air pressure as well.
View All My Models Here.
Old 09-25-2001, 11:18 AM
Anthony Anthony is offline
I had a similar problem, and it was caused by a slow punture in the tyre causing low pressure (about 1.5bar). Check the pressures are the same as those listed on the drivers door pillar (around 2.1bar I seem to remember).
Owner of Primeraweb, and a 1997 Nissan Primera SRi driver
Old 10-17-2001, 11:14 PM
GtRider GtRider is offline
Send a message via AIM to GtRider
wheel shaking!!!
when i jack up the front of my car,
i can shake the driver side tire!
yes i can shake it while it still bolted to the car.
what is making it shake?????
Old 10-18-2001, 12:23 AM
kenchan's Avatar
loose bolts on your arms..? hubs? need a new car?
Old 10-18-2001, 05:45 AM
T4 Primera T4 Primera is offline
Re: wheel shaking!!!
Could be a number of things, wheel bearing, suspension bushes ball joint, or just the strut loose in it's mount. You need to get it up on stands and have someone wiggle it while you look for where the movement is originating.
It might well be the third link where the play is. IIRC, many P10s have unjustly failed warrant of fitness inspection due to excessive play in the third link (the arm which attaches from the body, in the wheel well, to partway up the strut), although the Nissan specs allow for up to 1/4" of play. I read this in a U.K. vehicle inspection authority bulletin somewhere but I'm having trouble finding it again.
"The cause of liberty becomes a mockery if the price to be paid is the
wholesale destruction of those who are to enjoy liberty."
-- Mohandas Karamchand Gandhi
"They that can give up essential liberty to obtain a little temporary safety
deserve neither liberty nor safety."
-- Benjamin Franklin
"The biggest cause of trouble in the world today is that the stupid people are
so sure about things and the intelligent folks are so full of doubts."
-- Bertrand Russell
2002 Camry Tire Wear MHawker Camry/Camry Hybrid/Vista 16 06-29-2011 04:44 PM
Tire wear on the outside of both front tires burnsie629 Rodeo | Passport | MU 2 07-23-2004 02:45 PM
Tire wear? reepsmac Engineering/ Technical 2 08-05-2003 08:20 PM
Tire Wear and Tear xterrase Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail 5 05-27-2003 02:59 PM
Unusual tire wear ty423 Suspension 14 12-19-2001 05:36 AM
