Old 08-03-2003, 08:41 AM
reepsmac reepsmac is offline
Tire wear?
Around how much of a tires life is taken away when you lower your car and is it worth the cash to buy a camber kit to fix it?
Old 08-03-2003, 11:33 AM
kwik46 kwik46 is offline
Yea man, it is worth it to buy a camber kit. Think about it...you can get a decent camber kit for $100-$200 that is permanent. By not fixing your camber angles, you are forcing about 10-20% contact patch to do all of the work that normally is done by the whole contact patch. This causes your tires to wear out very quickly. I have seen tires wear through to the cords on the inside of the tire and have nearly new tread on the outside. If you figure that you can get a set of tires to last twice as long as they would have without the camber kit, then the kit has already payed for itself.
Another tip: If you are lowering your car by extreme amounts you may not want to fix the camber issue without checking what clearance issues you might have eg: tire to fender.
Old 08-05-2003, 08:20 PM
Thanks for the info
2002 Camry Tire Wear MHawker Camry/Camry Hybrid/Vista 16 06-29-2011 04:44 PM
Tire wear on the outside of both front tires burnsie629 Rodeo | Passport | MU 2 07-23-2004 02:45 PM
Tire Wear and Tear xterrase Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail 5 05-27-2003 02:59 PM
Unusual tire wear ty423 Suspension 14 12-19-2001 05:36 AM
tire wear rickp Maintenance 7 10-18-2001 05:45 AM
