Go Back   Automotive Forums Car Chat > Toyota > Supra > Maintenance
Maintenance Have questions? Find answers. Help out fellow Supra owners.
Old 11-24-2007, 08:14 PM
rking828 rking828 is offline
crank pulley
has anyone changed crank pully with engine in car. if so what tools are needed and how much of a pain is it. any help would be appreciated
Old 11-26-2007, 09:03 PM
TcmaBoy's Avatar
TcmaBoy TcmaBoy is offline
AF - Advisor
Re: crank pulley
You have to tear down the front of the car and remove the radiator to get to the pulley. You will need a 3/4 impact wrench, a TQ wrench, and a big puller.
I again recommend that you get a used motor rather than rolling the dice on the crank or main bearings being damaged.
Don't you SAS me boy.
Please wheel responsibly.
http://www.treadlightly.org/
Old 11-29-2007, 01:26 PM
Brian R.'s Avatar
Brian R. Brian R. is offline
Resident Chemist
Send a message via Yahoo to Brian R.
Re: crank pulley
I've been told that you can loosen the crank pulley bolt by placing a breaker bar/socket on it (with or without a cheater bar) so that the breaker/cheater bar rests either on the frame or the floor (to the driver side) and just nudging the starter.
To remove the pully, you will have to remove enough stuff to allow access (clearance).
Forum Guidelines:http://www.automotiveforums.com/vbulletin/guidelines.html
"What we've got here is a failure to communicate"
Old 12-01-2007, 06:56 PM
silversup silversup is offline
Re: crank pulley
Put the car in 3rd or 5th gear (forget which one did the trick for me), put the parking brake up. Have at long breaker bar ( i think the one i used is like 2 ft). Give it some oomph.
Old 07-18-2010, 04:50 AM
tank2done tank2done is offline
Re: crank pulley
Does the crank pully bolt turn counter clock wise, (left hand threads)?
