| Engineering/ Technical Ask technical questions about cars. Do you know how a car engine works? |
Roll Cages
I am designing a Roll Cage (Using CAD+FE) and trying out new materials for testing/analysis. Commonly used materials i found are:
![]() OutCell |
Re: Roll Cages
Is it for competition use? If so there should be a specs list which tells you all the suitable materials.
Otherwise it depends on your intended use more than anything else. Some applications where weight is a priority dictate that you use higher strength steel with thinner walls and/or smaller pipe. Other applications where rigidity is the main concern, there may be no point in going to a higher strength material. |
Re: Roll Cages
Chromemoly is usually considered the strongest, but it requires pretty specialized welding procedures. For that reason, seamless DOM steel is often used. Put it this way, welded seamless DOM is stronger than plain welded chromemoly since CM requires pretty careful welding heat to get it right. If you just smack a CM cage together without careful welding, its pretty useless.
Dragging people kicking and screaming into the enlightenment. |
Re: Roll Cages
Well it is just a speculation of an international Rally Car roll cage but i was collecting every material i was coming across and i got the list i mentioned above.. It should be strong but light
Thanks for your reply mate ![]() Quote:
Re: Roll Cages
Thanks mate
