Go Back   Automotive Forums Car Chat > Toyota > Camry/Camry Hybrid/Vista
Old 11-17-2007, 03:10 PM
Delta Dart Delta Dart is offline
Looking for distributer seal kit instructions
1990 Camry 3S-FE distributor has internal and external oil leaks. Found the kit and recall seeing the instructions posted somewhere but am currently unable to locate them. Are they supplied with the kit? Any new info on this repair?
Thanks!
Bill
Old 11-17-2007, 06:42 PM
JOET/CAMRY JOET/CAMRY is offline
Re: Looking for distributer seal kit instructions
Thanks!
Bill
Here is a couple of links that might help you.
http://www.automotiveforums.com/vbul...d.php?t=681293
http://www.automotiveforums.com/vbul...hlight=TOWNCAR
replacing the external distributor oil seal is fairly simple but I heard replacing the internal distributer oil seal is somewhat difficult. I don't think the links contains any instructions on replacing the internal dist. seal. Good Luck. BTW, if you rebuild the distributor please post back and let us know how it turned out.
Regards,
JOET/CAMRY
Old 11-18-2007, 01:58 AM
Good links. Thanks for the response JOET/CAMRY.
Old 11-26-2007, 01:33 PM
Took the easy way out and installed a reman from Napa. The bottom mount bolt was missing. Could this have caused the shaft seal to leak?
Old 11-29-2007, 11:39 PM
When you say the bottom mount bolt was missing, are you refering to one of the 2 timing adjustment bolts for the distributor?
If yes then I doubt that would cause the internal shaft seal to leak. It might of caused the outer seal to leak oil onto the engine.
Regards,
JOET/CAMRY
Old 12-01-2007, 01:31 AM
Regards,
JOET/CAMRY
Incorrect nomenclature on my part. Yes, I am referring to the 2 timining adjustment bolts/outer seal and external leak.
I have agreed to fix ALL of the oil leaks on this vehicle. The car belongs to a friend of my daughter. I have corrected leaks at the oil filter, oil pressure switch and distributor.It is still leaking oil from somewhere. Can the oil pump/crankshaft area be viewed at all with the upper timing cover removed?Thanks
Old 12-01-2007, 11:22 AM
Not with the upper timing cover removed but with the lower timing cover removed you can.
Regards,
JOET/CAMRY
Old 12-01-2007, 03:42 PM
Smile Re: Looking for distributer seal kit instructions
Regards,
JOET/CAMRY
Thanks JOET/CAMRY.Im new to the Camry and appreciate the input. I may have questions later on regarding seal replacement (will do a search first).
Thanks again.
Bill
