Old 11-08-2007, 05:03 PM
shawn7555 shawn7555 is offline
2oo4 gtp will not start
I stopped at a gas station today to grab a soda and when I came back out car would not start. It would not turnover or click like the battery was going dead. The hud showed 12.5 volts and I have lights and stereo and everything else. Checked the ign relay and also the starter fuse and ign fuse both were fine. Also tried to start the car in neutral nothing. Any suggestions?
Old 11-09-2007, 12:35 PM
GTP Dad GTP Dad is offline
Pontiac Guy
Re: 2oo4 gtp will not start
Welcome to AF!!
This sounds like one of three problems. Bad Battery, Bad connections to the battery, bad starter solenoid. I would start by checking the battery connections by removing them and cleaning them. Then check the ground wire that goes to the block and the hot wire that goes to the starter. If that doesn't help then try jumping the car with another one. If it won't turn over then you will need to check the starter solenoid and starter!
Old 11-09-2007, 03:09 PM
Checked the wires and had the battery tested. I jumped the solenoid to the starter with a screwdriver engine turns over but will not start. For some reason I seem to think this car has an anti theft that will kill the ignition is there a way to manually reset that?
Old 11-09-2007, 03:16 PM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
The factory security system disables the starter and the fuel pump. That is why even when you jump the starter solenoid, it turns over but won't start.
Still waiting for the "good old days" I'll get to bore my future grandchildren with!
Old 11-09-2007, 07:24 PM
I have tried both of my keys, locked and unlocked via keyless remote the only thing that seems odd with alarm when set if I attempt to open door with the key alarm goes off. Is there a way to reset this?
Old 11-10-2007, 07:36 AM
ponchonutty's Avatar
ponchonutty ponchonutty is offline
eww, it sounds like your BCM is failing. You actually have 2 alarms. One inside the ignition and one that goes off when a door is opened. It should disarm with the remotes. Have you tried unlocking the passenger door with the key?
Silverado Ext. Cab 4x4 z71
Pioneer 4900mp
Orion P6.2 Componet sets front
Orion C63 Coax rear
DirectedVideo 9" all in one DVD with surround
2007 SATURN OUTLOOK AWD XR with full entertainment package
Old 11-10-2007, 12:34 PM
It does not have passenger door lock, just driver side I guess I should just replace bcm? Does anyone know if these need to be flashed or anything like that. Thanks
Old 11-11-2007, 06:50 AM
Can't you get it to disarm with the key in the driver's door? Yes, you'll need to have the BCM reflashed while you have all of your ignition keys present.
Pioneer 4900mp
Orion C63 Coax rear
Old 11-11-2007, 08:27 AM
BNaylor's Avatar
BNaylor BNaylor is offline
The 2004 and up Grand Prixs should have the Passkey III VATS system. If it were a Passkey III problem preventing starting then hopefully there should a SECURITY light on either steady or flashing.
Also, it sounds like the OP has a Content Theft Deterrent Alarm System which is an option. Not sure on the '04 and up models but the '97-'03 equipped with the CTD alarm system have a red led in the middle of the dash. When flashing it is armed. Once armed the doors will not unlock with the power door lock switch and the alarm should sound if someone enters the vehicle without using the RKE, use a key to unlock the doors, or inserts the key to turn the ignition on, damages the vehicle or tampers with the trunk lock. In this case the CTD alarm system may not be disarming.
The problem is advanced diagnostics is required using a Tech II at the dealer. The dealer can pull any BCM codes causing the issue. As pointed out the BCM module will need to be programmed if replaced and only the dealer can reprogram the remote keyless entry system.
Timeslip 08/12/06
AF Community Guidelines
Old 11-11-2007, 10:07 AM
tblake's Avatar
tblake tblake is offline
In God We Trust
so my car has a cdt alarm? What happens if I lock the doors with the key fob and the battery dies and I have to use a key to get inside my car?
AF "2.0" Community Guidelines
Conservative Victory 2012!!!
Old 11-11-2007, 10:08 AM
tblake's Avatar
In God We Trust
also, Has the origonal poster looked to see if maybe he has an aftermarked remote starter installed?
Old 11-11-2007, 10:12 AM
BNaylor's Avatar
With the battery dead you think it will work? Probably a moot issue and I'm quite sure the key will get you in. Rich should have the GM RPO code for the CTD alarm system so send him a PM with VIN and he can tell you. Do you have the red led on the dash?
Timeslip 08/12/06
Old 11-11-2007, 11:04 AM
According to my information if the vehicle has the CTD (which since it is a GTP, it should) you should be able to disarm it with the key in the door. There's a small purple wire that comes from the lock and goes to the BCM. When it goes to ground, the alarm disarms.
Do you have any theft lights on????
Pioneer 4900mp
Orion C63 Coax rear
Old 11-11-2007, 11:42 AM
BNaylor's Avatar
I agree to a point because technically if the CTD is setup with the factory default that is true but we do not know if that is the case or how it was setup. There are multiple modes you can program. One is you can only activate or disarm the system with the RKE and the driver's side key disarm will be inhibited. On the '97-'03 factory default is Mode 4. The '04 and up are programmed similarly and the instructions is in the owner's manual normally in Chapter 2 which I would recommend reviewing. For example Mode 2 is RKE operation only with no key. Also, one of the modes, Mode 3? is total disable of the CTD.
Timeslip 08/12/06
Old 11-11-2007, 03:09 PM
I do have a red led on the dash that turns to blue after disarm with keyless. But It is now flashing in 3 light blinks it will pause and repeat the sequence. I went through the personal programing menu and disabled anti theft but same result. I am having it towed to dealer tomorrow, thanks for all the responses.
