1990 APV dies going into any gear
I want to thank all those that have had simlar problems of the vehicle as it has helped me narrow down the troubleshooting. I have had this van for about 6 years and it has been sitting in storage after I bought an Aztek for my wife, recently I needed it for another family member, this last thursday I had to have it towed back home when it kept dying everytime you tried to put it in gear, I found this forum and I am going to check it out, if indeed that is the problem then I may just connect the solonoid wires to a remote dash switch so it would be an open circuit like it was unplugged but can be closed for highway speeds to lock in the torque convertor until I find the time to do the repairs.
I have been a mechanic all my life except my field the last 15 years has gone strictly to heavy equipment so I am out of touch with the new stuff, last time I was a dealership mechanic was around 1984. |
Re: 1990 APV dies going into any gear
I suspect a stuck TOrque CONverter CLutch, or rather stuck TCC solenoid. Does it sputter or cough slowly to extinction or rather it acts just as if you had the car in gear and released the clutch on a sudden with a manual transmission ? That is, it "jumps" a few inches and that's all....
If it verifies this diagnostic, some help here: http://www.automotiveforums.com/vbul...d.php?t=551757 Since it happens right at startup, it might not be possible to do this test (it worls with those where it happens after the car has been driven for some time) but you can try anyway: unplug the TCC connector www.avigex.ca/xport/3T40tccplug.jpg THis would not help at startup because normally it is unergized then, but if you end up being able to start it and run, (may be by letting it go up to temperature before engaging into gear) it will prevent it from happening again by running without TCC..until you change the solenoid.
'93 Ponty Transport 3.8; 2011 SUzuki SX4 AWD (wife's) ; 2015 Sorento 2.4 AWD 1928 Graham Paige Model 629 I don't believe in miracles. Last edited by LMP; 11-04-2007 at 09:58 AM. |
Thats exactly what happens from reports, my wifesays anyway, its like popping the clutch. I've been laid up for two weeks with a broken hand but maybe tomorrow I am going to find that plug, unplug it and see what happens, if so a "cheat" might very well be a simple toggle switch she can flip at cruising speeds to lock it back in, unlock when starting and stopping.
2002 Silverado 3500 extended cab 4x4 dually 8.1 (496cid) Vortec, Allison 5spd w/OD All front lights, fog lamps converted to 5000K HID, all running lights chip LED Modded from LED sign double row red LED sequential T/S, running and brake lights mounted below tailgate. New side and rear modded emblems for visual effects. Escalade instrument cluster and auto dim LED outside mirrors. Front and rear concealed amber Tomar strobe system Modified for Alaska extremes |
'93 Ponty Transport 3.8; 2011 SUzuki SX4 AWD (wife's) ; 2015 Sorento 2.4 AWD 1928 Graham Paige Model 629 I don't believe in miracles. |
