Go Back   Automotive Forums Car Chat > Ford > Explorer | Explorer Sport Trac
Old 11-02-2007, 10:50 PM
muzzy1maniac's Avatar
muzzy1maniac muzzy1maniac is offline
Fuel Filter Replacement w/pics
I found there was no How-To on fuel filter replacement on this site so I thought I'd add one. I just got done with it so here it goes:
First off, this was done on my 04 Explorer 4.0l with 29k on it. I've been suffering from the shakes at idle. It seemed to happen after getting gas at Delta Sonic.
Your experience may be different depending on model and year.
Tools:
ratchet
10mm socket
13mm socket
Ford fuel tool
rags
new filter
safety glasses
Step 1:
Pull fuel pump relay #48 and start truck. Truck may run and stall or not run at all.
Block rear wheels and raise front end. Only the passenger side is really necessary. USE JACK STANDS
Locate filter. It's on the passenger side at the front/top of the fuel tank. It has a plastic cover then an aluminum heat shield over it so you won't see it.
#4 remove heat shield. Held on by 3 13mm bolts
heat shield
#5 Remove plastic cover. Held by 2 10mm bolts
Plastic cover
Now you can see the filter.
Remove the hose connections. The output side has a funky metal clip that needs to be slide towards the filter a bit then pushed up to disengage. Use the Ford tool to remove the output side hose. This goes over the filter tube and slide under the hose connection. You'll have to play with it a bit but the basic idea is to slide the tool under the fuel line connection releasing the internal spring and it'll pop apart. This is not fun since there is little room and you are on your back. The input side of the filter uses a different connector. It has a red plastic clip that needs to be undone. It's similar to the plug wire guides. I used nothing more than my hands. Once open gently push the 2 ends up to release the filter. It's kinda like a upside down U.
You know those black caps that are on the end of your new filter? They're great for capping the old filter while your working on it.
Ford Tool
#7 remove filter from bracket
Don't try pulling it out - that sucker is really in there. I used a rubber mallet to tap the filter out.
REMEMBER THIS IS A GAS FILTER - DON'T USE A REGULAR HAMMER!!! Use a block of wood if you have to.
#8 install new filter.
I put a light coating of grease on the new filter to help slide it back in. Should help with removal next time too. Make sure you have the filter in the right direction.
Filter in bracket
Reattach fuel lines. No biggie here - just reverse of removal.
Now is a good time for anti-seize on the bolts for next time.
Put the cover and heat shield back on.
Replace relay
Start truck and check for leaks.
Now here's the kicker. The truck ran beautifully! I only let it run long enough to check for leaks but there were no shakes!
Then I did what I always do to feel better about the busted knuckles and hard work I just put in - I poured the contents into a water bottle...
Damn! That's nasty! Remember I've only got 29k on my girl. How many do you have and when was the last filter change?? Go out and do it now!
2004 Explorer XLT
4.0L 4x4
1998 Ranger Supercab
4x2 3.0L
Anyone who said There Is No Such Thing As A Stupid Question never worked in a grocery store!
Come visit me on www.faceforums.com
Old 11-03-2007, 12:46 PM
xFatcatx xFatcatx is offline
Re: Fuel Filter Replacement w/pics
Good post, pics are always great. Not sure about your year but on my 99 sport the fuel inertia switch is under the glove box located by the passengers right foot. You pull the carpet back and will see a little black box with a red button, slide a screw driver underneath the button and pop it up, then let the truck run until it dies to release the fuel pressure in the lines. Just press the button back down with your finger when your done with whatever your doing. Its the same as pulling the relay.
I was going to change my filter last weekend but I cannot get it off. Both in and out lines to the filter are the quick disconnects (quick my azz). I litterally have sore hands, i tried the tool you have but there was not a small enough size on it, i went and got the plastic clips and still cant get it. 80000miles and im sure its the stock filter, i bought the truck when it had 44,000 on it and it came from Jersey i think so everything is pretty ugly underneath there. I really dont know what to do now other than cut the lines and replace them.....suggestions gladly excepted. this should be a sticky.
Old 11-03-2007, 02:15 PM
shorod's Avatar
shorod shorod is offline
SHO No Mo
I had similar difficulty with the release clips on the fuel filter of my 2000 Mountaineer. I was about to give up and decided to give it one last try. Well, for some reason it decided to give up on my last try and came loose. I actually think I was trying too hard to get the clips to release. When I didn't try to force the release tool, they lines came loose quite easily.
-Rod
Old 11-03-2007, 06:22 PM
thanks rod ill try it again. i am pretty buff...........ill go easy on it.lol
Old 11-03-2007, 06:38 PM
The clips are royale pains. Once the tool is in it's sort of a push pull thing. I had my fingers wedged between the filter and the tool and then pushed the connector then pulled. It's more gentle than you'd think. It's the lack of room to work and our big manly hands that get in the way. It's been a couple of days and I still feel it a bit.
As for the shut off. Pulling the relay seems easier - my .02.
2004 Explorer XLT
4.0L 4x4
4x2 3.0L
Old 11-06-2007, 09:14 PM
marquis00 marquis00 is offline
yeah on my 01 explorer i had the fuel filter with three connections, two of them being different sizes. it was a pain in the a@% to change out, but advance auto part has a set of aluminum quick releases for twenty bucks that made it alot better than the plastic ones. ohh, nice touch on the pics
Old 11-07-2007, 05:31 PM
Never seen the triple hoses. Damn - that sucks!
Yeah!!! Stickied!!!
2004 Explorer XLT
4.0L 4x4
4x2 3.0L
Old 11-07-2007, 07:40 PM
way2old's Avatar
way2old way2old is offline
TOKEN HILLBILLY
Figured it would do more good here than having to chase it all over the forum.opcorn:
Being way2old is why I need help from younger minds
The sooner you fall behind the more time you'll have to catch up.
HEY Y'ALL--READ THIS
Here are some of our old vehicles for sale.
Old 07-11-2008, 01:12 PM
realmntwin realmntwin is offline
I think it's funny that Ford puts in 10 and 13 mms in things like oil pan/filter water pumps, etc. But on the same car will have 1/2 and 5/8 on everything else to get there like the tensioner or fan shroud.. I think they want us to buy more tools!!
Old 10-29-2008, 12:23 AM
Huney1 Huney1 is offline
You can thank Jimmy Carter for bring metric tools to the American assembley line because it all began during his administration. Just another one of our lame governments stupid actions, and you ain't seen nothin' yet.
Old 09-27-2011, 10:29 AM
rlalle rlalle is offline
I also have the 3 outlets on the fuel filter,,,i found that PB Blaster helps in removing the filter clips from the line.
