Old 10-26-2007, 10:56 PM
2string 2string is offline
OEM Oil Filter
Well I bought an OEM oil filter today for my new 2003 4.8 silverado. I could not beleive how small it is. It looks like about the same size as my lawn mower filter. The parts guy said it's the same size as the 5.2 and the 6 liter.WOW! Should I use it or get a Wix or something else that holds a quart? Will the small one do as good a job?
Old 10-26-2007, 11:11 PM
abaird abaird is offline
Re: OEM Oil Filter
It will be fine. The older 5.7s that were 4wd had small filters too. I always say that if it is good enough for the manufacturer, it is good enough for me.
2009 Silverado 1500
2002 Camaro Z28(rebuilder)
2005 Yamaha GP1300R
Old 10-26-2007, 11:37 PM
'97ventureowner's Avatar
'97ventureowner '97ventureowner is offline
Re: OEM Oil Filter
There might be another A C Delco filter that is bigger(more capacity) that will work.About 15 years ago while working in a parts store we discovered in the back of the Fram sales catalog a breakdown of all the filters by dimension, thread size and whether it had a drainback valve or not. You could look up the original sized filter for your vehicle, and then go down the chart and find one with the same dimensions that was longer. I used to do it all the time back then with my filters, but can't remember the numbers I used. I believe there is such a reference still available today, and I'll check around and post back in a couple of days if I come across something.
Thought for the Day… Alcohol does not make you fat - It makes you lean... against tables, chairs, floors, walls and ugly people.
If a prostitute here in America loses her job to a prostitute in India , is that considered "outwhoring"??-Jay Leno
" A Good Thing To Know"
Old 10-26-2007, 11:40 PM
HC2000 HC2000 is offline
Registered User
Re: OEM Oil Filter
Hi, I have a 5.3 with just under 150,000 mi., and it has had only the small filters used on it. I believe if you change your oil as you should you will not have to worry about the size of the filter. 2string also remember the mower probably has a larger filter in comparison to your truck because it is operated in dusty conditions that will always contaminate oil quickly.
Old 10-27-2007, 11:56 AM
Re: OEM Oil Filter
That's a good reason for using the original filter for your truck. Over the years have encountered customers who desired a larger capacity for oil in their engine. My thoughts are that GM tries sometimes to get away with "whatever works minimally" and the engineers who design the parts probably take that into consideration, to save overall costs and improve the "bottom line". Increasing the capacity through using a larger filter, (in those applications where you can do so,) can have positive effects on lubrication, and more contaminate holding capabilities, all for the smaller cost of a filter 'upgrade'. Some larger filters don't even cost more than the original size. I've had some help from a guy who is fairly well known on my area for building racing engines as well as street applications. He always recommends to his customers to use a larger capacity filter where it is allowable instead of those remote oil filter relocation kits that use two separate filters, and extra oil lines to deliver the oil from the engine to those filters.
Yes, the original filters do a good job at filtering your oil, especially if changed on a regular basis, but if you could get better results using a larger filter for a few cents more, or even the same cost, wouldn't that also benefit your engine?
Old 10-27-2007, 04:27 PM
J-Ri's Avatar
J-Ri J-Ri is offline
Re: OEM Oil Filter
If there is room for it, a larger filter would work (although it seems like the front driveshaft would prevent it in a 4x4). If I remember right, the stock filter (Hastings#) is LF232. An LF393 (maybe LF164, I havn't done an oil change in a while) has the same threads and O-ring and is about 2-3 inches longer. Anyway, whatever brand you use, I'm sure they make a larger filter. Try looking up one for a '92 Cadillac DeVille, I'm pretty sure they use the larger filter that would work on your truck.
I can't even remember how the filters mount (horizontal, vertical, angle), but it would be good if you fill the filter with oil (as much as you can) before you put it on the truck. Probably not as big of a deal on the newer trucks that are still flowing plenty, but on my old '86, the lifters will click for 30 seconds if i leave the filter empty (nearly 3x the capacity of the stock filter)
'04 Cavalier coupe M/T 2.2 Ecotec
Supercharged 14 PSI boost, charge air cooler, 42# injectors
Tuned with HP Tuners
Poly engine/trans/control arm bushings
Self built and self programmed progressive methanol injection system
Old 10-27-2007, 06:46 PM
j cAT j cAT is offline
Re: OEM Oil Filter
I use the PL25288 PURE ONE BY PUROLATOR changed from Ac delco PF -59 when it was discontinued to the smaller size. I tried most of the oil filters and cut them open after use the purolator has the same filter media density as the ac but the drain back valve is better. wix 51522 is also a good filter this is same as the purolator pure one . purolator is easyier and cheaper to buy. Wix may have to call around to find store that carries this one. advanced autoparts carries the purolator good pricing. If you live in a hot climate or tow or go off roading dusty areas use larger filter for greater flow and cooling . In board boat engines always call for larger filters.
Old 10-28-2007, 10:25 PM
Re: OEM Oil Filter
Well greater flow and cooling in any condition sounds better to me so I guess bigger is better.
Old 10-28-2007, 11:22 PM
Re: OEM Oil Filter
FWIW: Here's a link to a study done on engine oil filters...an interesting read :http://minimopar.knizefamily.net/oilfilterstudy.html
Old 10-29-2007, 09:19 AM
silverado122775's Avatar
silverado122775 silverado122775 is offline
Re: OEM Oil Filter
I guess I will be changing my oil filter to the recommended ones.
2000 Silverado Z71, 5.3L, K&N GenII Air Intake, Y-pipe Exhaust (no muffler), Bosch Platnium +4 plugs, 242k miles and still running.
Old 10-29-2007, 11:05 AM
Re: OEM Oil Filter
What have you been using and what are you going to change to?
Old 10-29-2007, 11:21 AM
Re: OEM Oil Filter
I have been using Frame and Propulator. I think I will continue to use Propulator or AC Delco.
Old 11-01-2007, 07:39 AM
markz71 markz71 is offline
Re: OEM Oil Filter
i have a 5.3 i use ac delco ph 61 the other ones are to small
Old 11-01-2007, 07:52 AM
Re: OEM Oil Filter
Did you mean pf 61 and you are saying it will fit on my 2003 4.8?
Old 12-19-2007, 09:13 AM
Re: OEM Oil Filter
yes it will fit pf i mean been busy couldnt get back to you sooner
