Old 10-24-2007, 02:26 PM
jwk316 jwk316 is offline
98 Galant
Hello. I have a 98 Mitsu Galant ES and I switched it to synthetic around 106k but the previous owner said it burned oil. I really dont believe its a oil burning problem. I think its a leak from around the oil gasket area(where the oil pan bolts to engine block). It dont leak when it sits still, but when i look at the area it is really black and I tried tightening the bolts for the oil pan and they are pretty tight except for one was stripped(threads). It is barely even sitting there in the hole. So this is what I think the problem is. Is there a way I can fix this besides getting a new gasket and taking the pan off? Like maybe putting it up on a rack and cleaning it really good and JB welding the pan to the block? Thats just an idea. What do you guys think?
Old 10-24-2007, 06:14 PM
UncleBob UncleBob is offline
AF -Advisor
Re: 98 Galant
uh, don't glue the pan to the block. That would be a bad idea.
First thing you need to do is verify where its actually leaking from. I would pressure wash the engine (carefully) and then drive it 5 miles and look for new residue. With the number of miles, I would suspect the rear main seal first, but really it could be coming from everywhere
life begins at 10psi of boost
Three turbo'd motorcycles and counting.
Old 10-24-2007, 06:17 PM
Deus Ex Verra's Avatar
Deus Ex Verra Deus Ex Verra is offline
Re: 98 Galant
No, Don't weld it. Bad Idea. As far as the bolt, try getting another bolt to replace it. if necessary it could require a thread retap but that's better than the teflon bolt or JB welding idea. That should solve that problem
If you aren't sure where the leak is coming from just clean everything up real nice and do a few laps around the block and check for leaks and go from there.
1992 Honda Accord EX
Daily Driver
Stock 2.2L I4 4-speed auto
Old 10-25-2007, 03:09 AM
KiwiBacon KiwiBacon is offline
Re: 98 Galant
Does it have any blue smoke? I believe it's a mitsubishi trademark.
Old 10-25-2007, 03:21 AM
Moppie's Avatar
Moppie Moppie is offline
Master Connector
Re: 98 Galant
Especially if its a 4 cylinder Gallant.
I believe there was a recall done in the mid 90s though, apparently they engineered the head wrong, and the valves guides actually worked.
Old 10-25-2007, 12:40 PM
curtis73's Avatar
curtis73 curtis73 is offline
Professional Ninja Killer
Re: 98 Galant
Mitsu/chrysler had crazy problems with rings on almost all of their engines, most of them partially solved by 98, but they're not what I call durable rings.
Dragging people kicking and screaming into the enlightenment.
Old 10-26-2007, 11:28 AM
Re: 98 Galant
No blue smoke lol. There really isnt any color smoke coming out of the exhaust. It just for some reason loses oil. Yeah I am starting to learn that mistubishis engines are not even comparable to the other japanese engines. They also like to tick a lot with there lifters going bad. Really gay.
Old 10-26-2007, 04:47 PM
2.2 Straight six's Avatar
2.2 Straight six 2.2 Straight six is offline
That thing got a Hemi?
Send a message via AIM to 2.2 Straight six Send a message via MSN to 2.2 Straight six
Re: 98 Galant
haha.. welding the sump to the block. that's classic.
Seatbelts Saved My Life
Old 10-31-2007, 05:38 PM
Indy Tech Indy Tech is offline
Smile Re: 98 Galant
These engines start to leak oil when they get to around 60.00o m
they valve cover gaskets get hard and leak Rear crank seal also
timing belt should be changed around this time as the cam and
crankshaft seal also leak like crazy .
Greg.
indy shop owner/tech
