Go Back   Automotive Forums Car Chat > Subaru > Impreza/9-2x/Outback Sport
Old 10-23-2007, 07:18 PM
Phacops Phacops is offline
Unhappy Fresh Air Induction Problem
Have an 02 WRX wagon that I enjoy but am getting frustrated about a problem. Am not particularly mechanically inclined (do my own work on my Vulcan, but that's about it) so can use advice.
On fresh air and while idling at a stop there is frequently an exhaust smell that is getting into the car. It occurs when warmed up, whether I'm alone or not, and varies from slight to pretty noticeable depending on wind, temperature and humidity.
The local mechanic and Subaru tech. all blow me off saying that there are no complaints of this and that it is probably normal. Needless to say that is convincing me that Subaru makes a pretty crappy product and figures that poor service doesn't matter.
Any ideas where to look for a problem that may be small, chronic, and not appearing to affect performance (that at least is noticed by the service tech.)?
Old 10-23-2007, 07:21 PM
Jay! Jay! is offline
Horizontally Opposed
Re: Fresh Air Induction Problem
On an all-stock setup? How many miles?
Hierarchy of Subaru:
(Click to see mine!)
Old 10-23-2007, 09:21 PM
All stock,factory. 47,000 miles. Last repair - fuel rail, 02/07. Hope this helps.
Old 10-23-2007, 09:33 PM
freakray freakray is offline
AF Modelrater
Windows up or down.
Air on recirc or fresh air from outside?
Have you noticed a different exhaust pitch indicating an exhaust leak.
Check the seals around the rear lid for damage or crimping.
AF User Guidelines
Old 10-25-2007, 07:22 PM
Fresh Air, windows up. Slightly deeper exhaust note. The mechanic says he checked for exhaust leaks (now I'm thinking: "yeah . . . right").
If I have to check things myself, and knowing that I'm a complete tyro with cars, what do I look for - how will even a small leak show up if I have to get under the hood?
Old 10-25-2007, 08:12 PM
AF Modelrater
You don't need to get "under the hood", you will need to get under the car.
First sign will be black 'soot' along the tunnel which looks out of place, most exhaust leaks occur on the exhaust underside where condensation accumulates - look carefully for this.
Also check around flanges for any indications of gasket blow out.
The fact your exhaust note has got louder is a clear indicator of an exhaust leak.
Fact that you're on fresh air could indicate the leak is in the front end of the system.
AF User Guidelines
Old 12-02-2007, 05:22 PM
Re: Fresh Air Induction Problem - Update
Problem solved. It was not an exhaust problem, directly.
The PCV 1/2" hose was disconnected from its ferrule on the intake manifold. Not easily seen as it is under the intercooler.
