intermittent starting problem
I have a Trans Sport 94 3.8L. The van will run for about 20 min then either dies or if you turn it off it will not restart for a couple hours.
We Replaced the ignition module and it does the same thing. When it wont start there is no spark from the coil packs. I know its not fuel. Something electrical or sensor must be getting warm snd shutting off the signal to the Modulator I guess. But what could make it do this. Any ideas would be extremelly helpful. The coil Packs seem to work fine. Doubt all of them are bad. Bill |
Re: intermittent starting problem
It seems it is a trend...look adjacent threads: most common culprit with these symptoms: crank position sensor, at that age, almost a mandatory maintenance item.
http://www.automotiveforums.com/vbul...d.php?t=760671
'93 Ponty Transport 3.8; 2011 SUzuki SX4 AWD (wife's) ; 2015 Sorento 2.4 AWD 1928 Graham Paige Model 629 I don't believe in miracles. Last edited by LMP; 10-22-2007 at 05:53 PM. |
