Go Back   Automotive Forums Car Chat > Cars in General
Old 10-15-2007, 02:00 PM
Jarod_C Jarod_C is offline
Compression
I know there's no exact answer to this question, but please try anyway.
Is there a way you can approximately figure out what the pressure in your cylinder be by using your compression ratio?
If you can fill me in on the formula that would be great or figure it out for me.
The compression ratio is about 5.1
Any help would be great. Thanks.
Old 10-15-2007, 03:20 PM
Gohan Ryu Gohan Ryu is offline
Re: Compression
Too many variables. But as a reference a DSM 1G 1.8 litre running 9.0:1 compression should test at 185lbs and a 1G 2.0 litre running the same compression should test at 192lbs.
Old 10-16-2007, 03:03 PM
J-Ri's Avatar
J-Ri J-Ri is offline
Re: Compression
5.1:1 seems very low, even for a supercharged/turbo engine. What's the engine in?
'04 Cavalier coupe M/T 2.2 Ecotec
Supercharged 14 PSI boost, charge air cooler, 42# injectors
Tuned with HP Tuners
Poly engine/trans/control arm bushings
Self built and self programmed progressive methanol injection system
Old 10-16-2007, 06:09 PM
Re: Compression
It's an engine from a 1948 Farmall H. I know it might not be the right forum to be in for a tractor, but engines are engines I guess.
Old 10-19-2007, 02:13 PM
curtis73's Avatar
curtis73 curtis73 is offline
Professional Ninja Killer
Re: Compression
Like was said, too many variables. Theoretically, if the cylinders filled completely on each intake stroke, and if the valves and rings sealed perfectly, and if the ambient barometric pressure were 14.7 psi, then your compressed pressure should be (14.7 x 5) - 14.7 = 58.8. In truth, we can't know how the cam timing events, ring and valve seal, and actual VE of the engine, so actual pressures could be widely variant.
Dragging people kicking and screaming into the enlightenment.
