Go Back   Automotive Forums Car Chat > Ford > Explorer | Explorer Sport Trac
Old 10-15-2007, 08:54 AM
Country20 Country20 is offline
2000 Ford Explorer-Idles up and down
My explorer runs fine on road while driving. When stopping idle varies up and down, also gas mileage nil to none. Periodically runs rough, changed wires, plugs, fuel filter, and cleaned throttle body. O2 sensors operating normally per computer diagnostic examination. Have noticed when making left hand turn truck wants to stall. Please help!! My wife is all over me with this!!!
Old 10-15-2007, 09:50 PM
shorod's Avatar
shorod shorod is offline
SHO No Mo
Re: 2000 Ford Explorer-Idles up and down
You may want to check the Mass Air Flow (MAF) sensor to see how dirty it is. Not sure what would correlate to left hand turns, unless it's something like a weak fuel pump that can't create enough pressure when the fuel flows away from it.
Have you checked the fuel pressure?
-Rod
Old 10-17-2007, 07:02 AM
Thanks shorod,I am trouble shooting the (MAF) TODAY FOUND THAT THE VOLTS WERE LOW LAST NIGHT, VOLTS SHOULD BE ABOUT 3.0 BUT THEY WERE ONLY 1.1 LAST NIGHT SO WE WILL GO THERE FIRST. HOPE THAT WORKS! "DANG THE SENSORS"
Old 10-22-2007, 05:57 AM
Great news,
I did check fuel pressure and noticed that the pressure was only 40psi also it started dropping and that was causing my idle to go up/down. Fuel pressure dropped to 10psi and as it fell the motor was actually starving for gas! Changed fuel pump and all is well,gas milage is back up to 16.9 in city! Not bad for V8.Runs great! Wife is Happy!!!
Old 10-22-2007, 06:44 AM
way2old's Avatar
way2old way2old is offline
TOKEN HILLBILLY
Thanks for the fix reply. We appreciate you taking the time to post so others amy learn from your fix post. Good job.
Being way2old is why I need help from younger minds
The sooner you fall behind the more time you'll have to catch up.
HEY Y'ALL--READ THIS
Here are some of our old vehicles for sale.
