Go Back   Automotive Forums Car Chat > Buick > Roadmaster
Old 10-14-2007, 11:14 PM
ropergilson ropergilson is offline
Rear vent windows on RM Wagon leaking
I just bought a 95 roadmaster wagon with 87k for $1,500. The only thing it really needed was an ac compressor and the rear windows fell off it track. It looks like the rear vent windows have leaks. The metal trim directly under the windows is rusty and the paint is coming off. It also looks like there was was water in the tire compartment at some point. Is there anywhere I can get replacement seals? The old ones feel dried out and have hairline cracks forming. Thanks!
Old 10-15-2007, 08:40 AM
'97ventureowner's Avatar
'97ventureowner '97ventureowner is offline
Re: Rear vent windows on RM Wagon leaking
Have you tried the dealer yet? Some may still have parts in stock for these vehicles, or may be able to locate them for you. That would be the first place I'd try.
Thought for the Day… Alcohol does not make you fat - It makes you lean... against tables, chairs, floors, walls and ugly people.
If a prostitute here in America loses her job to a prostitute in India , is that considered "outwhoring"??-Jay Leno
" A Good Thing To Know"
Old 11-11-2007, 05:27 PM
I found some silicone spray helped. On the pass side though, I found that the hinge actually separated from the glass towards the bottom. Now when the window is open, the glass rattles and looks like it will fall off. What can anyone recommend for re-glueing metal to glass?
Old 12-01-2007, 01:34 PM
bocoogto bocoogto is offline
I had the same problem on my '93 Wagon. You can use glue that will stick to glass and metal to fix the problem. I used some of the gel Superglue by Loctite. It is possible to reach the surfaces to apply glue with the window still in the vehicle. Clean the surfaces as well as you can. Pick a clamp that will squeeze the hinge-to-window joint tightly while the glue dries. Did mine two years ago with no further problems.
