Old 10-13-2007, 07:34 PM
phillip.tucker21 phillip.tucker21 is offline
Very Weird Problem, help!!!!!!!!!!
Hey I have a 99 alero 3.4, I finally got my car to start, found out that my bcm wasnt getting any power. So I juumped the fuse off an always hot fuse. Car runs great. But now I have a problem, I can start the car when it cools down without a problem, but after I turn it off and try to start it right back up it wont start. I get no fuel on the rail, could it be my pump. I heard that some pumps will work when they are cool, but if it gets warm and you try to restart the pump will not work.I no its onot passlock problems, becuase I tried a new ignition cylinder and it does the samething as my old one. Any advice will help.
Old 10-13-2007, 07:43 PM
BNaylor's Avatar
BNaylor BNaylor is offline
Re: Very Weird Problem, help!!!!!!!!!!
Best thing to do since the fuel pump assembly is expensive and tedious to replace since the gas tank has to be dropped is run a fuel pressure check at the rear fuel injector rail (right side). There is a Schrader valve you can connect an automotive fuel pressure tester. Check pressure at fuel pump prime (ignition to on not start) initially and while engine is idling once you get the engine to start.
Timeslip 08/12/06
AF Community Guidelines
Old 10-15-2007, 07:35 AM
Big Problem
Im havbing a probvlem with my alero 99 3.4. If it has sat for a little while it will start up without a probvlem, runs bveautiful, but if I turn it off and kthen try to rrestart right away it wont start up at all, or it will startup and act like it is starvbing for gas. When I check the fuel rail there is no gas on it at all, ut if I wait a little while, I get gas on rail. COuld this be a fuel pump, I havbe read that they go out sometime when they get hot, and then when they get could they will start working again
Old 10-15-2007, 05:45 PM
BNaylor's Avatar
Re: Big Problem
phillip.tucker21,
Please try to keep your issue limited to one post/thread. I have merged your two posts together since they looked similar in nature.
BE COURTEOUS: AVOID DUPLICATE POSTS
Do not post the same discussion more than once on a discussion forum or on many forums. Duplicate discussions can be frustrating for other members, especially for those whose time and energy is limited. Weeding through the same discussion in multiple locations can be not only frustrating, but down right annoying. Duplicate discussions will be deleted. Reposting the same message repeatedly can be interpreted as SPAM and could result in the loss of your membership. Also be conscious of your fellow members and avoid making meaningless posts for the sole purpose of increasing your post count.
Timeslip 08/12/06
