Old 10-11-2007, 10:20 PM
Dave_s Dave_s is offline
Strange trany failure
The trany on my 97 sable stopped shifting. Strange part is that the speedometer and odometer stopped working prior to the shift problem. I'm thinking that something electronic went bad. Any ideas?
Old 10-11-2007, 10:28 PM
shorod's Avatar
shorod shorod is offline
SHO No Mo
Re: Strange trany failure
I'd start by checking/replacing the Vehicle Speed Sensor. Oh, wait, on your 1997, I believe that function is performed by the ABS controller. Any chance your ABS light is on too?
-Rod
Old 10-13-2007, 07:52 PM
The ABS light is not on. However, I had the speed sensor replaced about a year ago. I'm going to get the check engine light read (or pick up a scanner and do it myself) to see if thats the issue. What function are you refering to that is performed by the ABS sensor?
Old 10-13-2007, 10:35 PM
shorod's Avatar
SHO No Mo
I believe in the 1997 Taurus the ABS wheel speed sensors are used to provide vehicle speed data for the speedometer rather than using a Vehicle Speed Sensor as they did in previous years.
-Rod
Old 10-13-2007, 10:40 PM
shorod's Avatar
SHO No Mo
I was mistaken. I just pulled up the speedometer wiring diagram from the Factory service manual, and in a 1997 Taurus, the speedometer gets its signal from the Vehicle Speed Sensor (VSS).
Likewise, the VSS is used by the transmission for determining shift schedules.
-Rod
Old 10-13-2007, 11:46 PM
Sounds like a VSS is the way to go. Its not an expensive part (about $20) so I'll just replace it as an attempt to diagnose the problem. I'll let you knwo how it goes. May be a little while till I can get to it though.
Old 10-14-2007, 12:41 AM
worthirt_99's Avatar
worthirt_99 worthirt_99 is offline
I would fix it extremely soon if the odo is out also. that could cause legal issues when you are going to get rid of the car, if anyone knows about it.
Back home and I have my Taurus back!
Old 10-14-2007, 03:47 AM
ODO?
Not sure if its a legal issue anyways. I would have to junk it if I can't fix it. not many folks want a car that doesn't shift out of first.
Old 10-14-2007, 05:43 AM
Well then I'll retract my previous statement, especially if it's just gonna go to the bone yard, unless you get it fixed of course... I thought for some reason that you were still driving it (doh 1 for me )
Old 10-14-2007, 09:56 AM
what does ODO stand for?
Old 10-14-2007, 11:52 AM
shorod's Avatar
SHO No Mo
ODO = odometer.
Old 10-21-2007, 09:56 PM
I managed to get a code reader on the car. I have 2 codes. The first is the speed sensor that we expected (thats the good news). The second is P-1744. Is the trany dead, or is this a secondary fault because of the speed sensor? Also, is this likely a faulty sensor, or is the torch converter gone and I should just donate the car so that I don't have to pay the insurance anymore?
Old 10-23-2007, 10:58 PM
I found this post:
http://www.automotiveforums.com/vbulletin/t415152.html
That relates to my issue. they don't mention anything about the VSS but do discuss my code. It seems to me from that post thread that the VSS is trying to tell the torque converter to lock but it isn't listening. Is it worth the effort of replacing the speed sensor, or is it time to toss the car?
Old 10-24-2007, 09:42 PM
shorod's Avatar
SHO No Mo
Code P1744 indicates that excessive slip of the TCC was detected. It seems to me like the VSS could still be the culprit if the VSS is used in conjunction with the input shaft speed sensor to determine TCC slip. Certainly seems like the most cost-effective place to start anyway.
-Rod
Old 10-24-2007, 09:46 PM
Ill try the VSS and let you know how it goes.
