Go Back   Automotive Forums Car Chat > BMW > 5 Series
Old 11-28-2002, 08:35 AM
jterrell jterrell is offline
Question 525i overheating
My 525i starts overheating after driving a few miles. If the heater is turned on, the temperature guage goes back close to the normal range.
I have installed a new aftermarket thermostat but it still does the same thing.
Has anyone had a similar problem and has a solution to share?
Old 11-28-2002, 11:33 AM
cwsmith cwsmith is offline
check
Check your cooling fan system or your body grounds.
Old 11-29-2002, 12:03 PM
lvella lvella is offline
525i overheating
I had an overheating problem on my 1992 525i. I had to change the water pump and the thermostate. The Pump impeller is a composite material which had failed in my case.
Old 12-02-2002, 06:37 PM
jpohlman jpohlman is offline
My 325 was the same way. The plastic impeller broke. The dealer replaced it with the new metal impeller water pump. Apparently the changeover to metal impellers happened at the beginning of 1996. They replaced the termostat as well. According to my dealer, the thermostat is different from normal thermostats. There is wax in it that regulates the operation.
cheers
Old 12-06-2002, 09:43 AM
Seth4Man Seth4Man is offline
If your car is a 2001, it is likely that you still have the faulty fan. I worked at a BMW dealer while they were experiencing this problem. BMW had switched maufactures of the fans in order to save money. The fans, however, failed to come on when the cars needed them, and thus there was a substantial problem overheating. There was a factory recall of all 2001 BMWs, including the 525i, but if your dealer failed to notify you, there is no way you could know. If you take the car in, they will replace the fan and repair any other damage to the car at no cost to you. Good luck.
Old 12-08-2002, 07:35 PM
rachel3790 rachel3790 is offline
Unhappy 528I overheating
I have a 528I and it started overheating i replaced the waterpump the theremestate and it stilled overheated. I finally think i figured out what it's prob. is. There is something loose in the radiator. I have to get it flushed. It doesn't happen all the time. But if the thing in it is big enough it would. I figured it out when i took it someplace and they noticed that bottom of the radiator wasn't hot... which led them to figure out that the water wasn't getting all the way through it. Well i hope that helps.
91 525i idles at 5000 RPM!!!! HELP!!!!! Metalmatt87 5 Series 0 11-13-2010 12:09 PM
my 1997 dodge neon keeps overheating Lavette General Discussion 2 08-23-2009 07:15 PM
1999 contour overhating thermostat has been changed madd802 Contour 4 08-15-2009 09:42 AM
03 Alero overheating/puttering Grizzly5421 Alero 5 08-13-2009 06:44 PM
525I Overheating Mark Zaharis 5 Series 3 07-08-2009 02:51 AM
