Old 10-06-2007, 09:22 PM
krotta krotta is offline
Question gas have lubricating values ?
does gas have any lubricating value ounce in the cyl in a 4stroke engine.Understand oil is below rings lubricating. But i would assume gas has some sort of value besides just burning
Old 10-06-2007, 11:07 PM
mr_mushroom's Avatar
mr_mushroom mr_mushroom is offline
Send a message via AIM to mr_mushroom
Re: gas have lubricating values ?
what?
very unclear.
no. not that i've ever heard of.
it has detergents, though, so it DOES have value other than 'just burning', even if it doesn't lubricate.
all your are belong to us.
Old 10-07-2007, 06:17 AM
curtis73's Avatar
curtis73 curtis73 is offline
Professional Ninja Killer
No, not really. The rings get oil from below and the bottom-most ring controls how much oil the top two compression rings see. The amount of piston above the rings is less than 1/4" in most applications, so not only does it really need any lube, it rarely contacts the cylinder walls if at all.
So, for all intents and purposes... gasoline's only job in the cylinder is to go boom and make power.
Dragging people kicking and screaming into the enlightenment.
Old 10-07-2007, 12:00 PM
534BC 534BC is offline
Agreed, Gas will lubricate, but in cylinder it is in vapor state.
Old 10-07-2007, 01:40 PM
UncleBob UncleBob is offline
AF -Advisor
gas most definitely does not act as a lubricant. You should see the damage that occurs when an injector sticks open/leaks
I think this idea is from leaded fuel/unleaded fuel days. Many feared/believed that leaded fuel protected the valve seats and unleaded fuel would cause the seats to wear. The research I've done on that subject, I've never found a real example of this, although lots of people talk about it
life begins at 10psi of boost
Three turbo'd motorcycles and counting.
Old 10-08-2007, 01:15 AM
KiwiBacon KiwiBacon is offline
But they sold a hell of a lot of fuel additives.
