Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 10-04-2007, 03:38 PM
evildragon evildragon is offline
can't turn key sometimes
This is kinda ironic in my situation, because my fathers ex-police car starts without a key.
Mine however, sometimes won't even TURN with the key in it.. It's not a copy, it's an original GM key that came with the car, and sometimes I can't get it to even turn or unlock the wheel.
My one and only car!
1994 Chevy Caprice Classic LS
L99 Engine
Old 10-04-2007, 03:53 PM
PeteA216's Avatar
PeteA216 PeteA216 is offline
Send a message via AIM to PeteA216
Re: can't turn key sometimes
Since it's an original key it may be worn and isn't fully engaging the tumblers inside the ignition. Do you have a copy laying around anywhere? Or even another original? If you do, try one of those. If it still gives you trouble even with a different key, the problem lies within the ignition itself. If this is the case, then as long as you don't have the little chip on your key, try squirting some penetrating lubricant into the key hole. Sometimes things like to stick. Worst case scenario would be that you have to replace the ignition, which is actually a fairly simple and not-too-expensive thing to do assuming you have access to a steering wheel puller.
Old 10-04-2007, 04:09 PM
Mine does have PassKey, but I do know how to modify that if I have too. I know the resistance of my key's resistor, and can place a permanent resistor in the ignition switch if I must.
L99 Engine
Old 10-04-2007, 06:42 PM
PeteA216's Avatar
Do you have any more keys than just that one?
Old 10-04-2007, 08:11 PM
only one key..
L99 Engine
Old 10-04-2007, 09:50 PM
smallblockblues smallblockblues is offline
go to a gm dealer and give them your vin# and they will send you a new set For $200 smackers, had the same problem with a 96 sonoma sls
Damn passlock sytem!!!!!!!!!!!
Old 10-04-2007, 11:53 PM
moparvwfreak moparvwfreak is offline
thank god mines too old for the passkey BS.
dodges, dubs, chevys and now fords. i am a glutton for punishment.
Old 10-05-2007, 11:43 AM
PeteA216's Avatar
Since that is your only set you can't even get it copied because if you do the worn teeth in the key will be copied into the new one and doesn't solve your problem whatsoever. You might be stuck paying the $200 for a new key. Or you can go junkyark hopping and find another ignition for cheap.
Old 10-07-2007, 09:00 PM
Blue Bowtie's Avatar
Registered Offender
Or get a new VATS lock cylinder for about $45. That's what I paid about a month ago for an Olds (same column/lock as a Caprice).
Your other option is to lube the lock cylinder with powdered graphite and work it into the plate tumblers.
