Old 10-01-2007, 05:01 AM
3859C1 3859C1 is offline
New brakes, not much better
I just had new stock diameter drilled and slotted rotors and NAPA ceramix pads installed on my '97 GTP, but it didn't seem to make alot of difference compared to my old stock brakes. My girlfriend has stock brakes and pads on her '97 GTP and it seems to stop much better than mine. Her's really grab when you mash on the brakes. Any ideas why mine aren't as effective? Thanks!
Old 10-01-2007, 07:13 AM
BNaylor's Avatar
BNaylor BNaylor is offline
Re: New brakes, not much better
IMO the ceramic pads.
Timeslip 08/12/06
AF Community Guidelines
Old 10-01-2007, 07:50 AM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
IMO, it's both the pads and the rotors. Drilled and slotted rotors give less overall surface for the brake pads to grip. Their only advantage is in EXTREME braking like rally-cross racing or canyon carving in the mountains. In these situations, the rotors dissipate heat better and reduce fade. Otherwise, they actually reduce cold braking efficiency. That's why the OEM's don't use the carbon fiber brakes that Formula-1 cars have, they're not worth a crap when cold. Ceramic pads, while quieter and cleaner (no black dusting), have a slightly less maximum coeffcient of friction than a quality semi-metallic pad, so they don't stop quite as well in panic type hard braking.
Still waiting for the "good old days" I'll get to bore my future grandchildren with!
Old 10-01-2007, 10:15 AM
BNaylor's Avatar
The carbon pads have been homogenized or domesticated and work quite well now for non-racing applications. You can get the Performance Friction Carbon-Metallic pads which work pretty darn good even compared to the OEM. I use Performance Friction brand pads with Raybestos PG rotors. By compounding, the metallic improves braking. The carbon element provides stability at elevated temperatures whereby making the pads less likely to deform and deteriorate. Plus the cost is reasonable at $50 per set.
BTW - Although brake dust is still there it is minimal and these pads are quiet!!!
Timeslip 08/12/06
Old 10-01-2007, 05:10 PM
GTP Dad GTP Dad is offline
Pontiac Guy
I have to agree with both Rich and Bob! Heat the ceramics up and see who stops faster the performance friction carbon metallic pads are an excellent choice and I highly recommend them. I have had great success with them in the past.
