Old 11-27-2002, 08:18 AM
transam-blaze transam-blaze is offline
Send a message via AIM to transam-blaze
Unhappy smoke upon start up???
I have a 85 trans am with the 305 TPI all the org. engen.. it smokes for about 5- 10 seconds.. it look bad coming out the back of such a good looking car:bandit: so if any one has any Ideas about whats causing this hor how i can fix it . thanks for the help
1985 trans am: 305 TPI, auto, WS-6 hypertech chip, just picked it up about a month ago but now is snowing in michigan so no time to drive it, awesome ride.. 1998 blazer 4.3 k&n filter, ravin high pro muffler the mother is loud!!
Old 11-29-2002, 04:38 PM
Rixter Rixter is offline
Thumbs up Valve seals
pull valve covers and valve springs and change the valve seals , if you need help in fixing let us know.
:alien2:
Old 12-02-2002, 09:07 AM
so saying its just the valve seals?? well im not to good at fixin thing like that. how much do you think it might take it to have a shop do this? thanks for the reply!!:flash: :flash:
Old 12-02-2002, 09:29 AM
Cool valve guide seals
I'm not sure of price to change with heads on car, but they are easy if you have or can borrow a valve spring compressor. Remove valve covers,rocker arms and spark plugs, Find a 8.8 piece of spark plug wire (ha ha ) thats what I use works great, which ever spring your going with first push the plug wire in spark plug hole and spin engine by HAND until it stops, this way the valves will stay in place, with spring tool compress spring remove locks (2-pieces) Remove tool and spring and you will see seal good ones will have wire retainers. Thats what you should replace the old ones with,now with everything removed see if you can shake valve stem side to side, if it moves alot you should remove heads and have new valve guides installed, usually 10-15 a piece. Also when removing spark plugs (doing so after car sits long enough to cool) look to see what plugs are wet and that will save you from pulling all the springs. Hope this helps. If we were closer I'd help you out. lol.:sun:
Old 01-26-2003, 06:51 PM
Scott 02's Avatar
Scott 02 Scott 02 is offline
Banned
Send a message via AIM to Scott 02 Send a message via Yahoo to Scott 02
Its getting more fuel than what it needs at start. Does it seem to sputter for about 2-5 seconds and then start normal?
Old 02-27-2003, 09:57 AM
Ringo Ringo is offline
Banned
With an 85, wouldn't it be time for a total rebuild?
Old 03-02-2003, 08:24 PM
Scott 02's Avatar
Banned
Age dosen't mean that a motor is junk or is time for a rebuild. Our 86 fiero has 57,000 miles and runs great and age has nothing to do with it. Its Miles Ringo
Old 03-15-2003, 08:02 PM
Spyk Spyk is offline
Banned
Common prblemin cold weather state the rings nedtime to expand when they are warm they enlarge abit..
the real
? is since is ounlloy 10secondsis haw much oil do you lose between changes
also you can use a heavier starting oil like instest of 5w use 10 w or 15 w..thatwill take care of the problem.. and you mightwant tostay away from sythetic and shorted you dyno oil interval to 2000 miles.
this is a comon problemwiththe pre01 LS1 1 quartof oilis statard loss betwen 3koil changed.but we use 10 wand add one bottle of 15wand the problem is gene and they use tosmoke forlike 10-15 seconds on startupsolong as Wotyou don'thave smoke...havesmeone look foryou
Old 04-04-2003, 10:31 AM
Banned
aalsif it wight smoke it ring bloe by tillthe rng s expand..i oudn'tworry bout it for 1 seconde=s...also it its col and yo dont have cats it more likely moister...in the pipes
Old 04-04-2003, 04:08 PM
Scott 02's Avatar
Banned
Translation please. I can't read this.
Old 04-05-2003, 05:22 AM
Banned
iF SMOKE IS PRESENT UPON STARTUP..ONE ITS MINOR WRING BLOW BYE.. WHEN THE PISTONS EXPANDS THE SMOKE DISAPEARS
TWO ITS A DESIGN FLAW THAT MANIFESTS ITSSELF IN COLD WEATHER PISTON SHRINGAGE.
tHREE IF YOUR CATLESS. MOISTURE FROM THE DAY BEFORE WILL CAUSE STEAM OUT OF THE PIPES.. I HAD THIS AND THOUGH MY ENGINE WAS RUINED.. UNTILL I SPOTTED THE WATER DROPLETS.. CHECH TO SEE IF ITS RESIDUE.. IF ITS BLUEISH THEN ITS OIL BLOW BYE.. BUT IF IT STOP AFTER 5-10 SECONDS ITS NOTHING TO WORRY ABOUT IMMEDIADETLY.. IF HOWEVER WHEEN YOU PUNCH IT AND BLUE SMOKE COMES OUT THEN YOU HAVE A RING PROBLEM..
REMEBER ITS GOTTA BE WHITISH NOT BLACK WHEN YOU PUNCH IT OTHERWISE ITS JUST MINOR WRING
Old 04-30-2004, 11:07 PM
383chevyZ71 383chevyZ71 is offline
These engines were known to smoke on start up. The valve seals apparently weren't very good and allow oil to leak down from the heads into the cylinders while sitting overnight etc... It really isn't a big deal if you don't mind the smoke. I have and 85 TA and it has smoked like that since around 100,000 and now has over 200,000 and has been driven hard the whole time.
Old 05-04-2004, 05:11 PM
tacoma man tacoma man is offline
Re: smoke upon start up???
just change the valve seals, how many miles
does it have? my brother has a 86 trans am
with over 230,000 miles on it. runs strong,
it smoked when we would start it up,
but wouldnt smoke no more. we had the
heads redone at a local performance shop
that builds racing engines, $235.00
and no more smoke. but this is on a
carb'ed engine 5.0 liter h.o. i think
it might be more for a f.i. engine.
some smoking upon start up chevyrulespops S Coupe 0 04-25-2009 10:27 PM
1997 Jeep GC stalling upon start-up rapamg8 Grand Cherokee | Grand Cherokee SRT8 8 08-28-2006 02:37 PM
skylark idles rough upon start up county_boy30 Skylark 3 12-27-2005 08:49 AM
95 rough idle and stall upon start up Purpleteeth Continental 1 08-15-2005 08:59 PM
2001 LeSabre Noise upon start up labinss LeSabre 2 07-30-2004 08:49 PM
