Go Back   Automotive Forums Car Chat > Buick > Skylark
Old 12-08-2005, 04:26 PM
county_boy30 county_boy30 is offline
Send a message via MSN to county_boy30
skylark idles rough upon start up
I have a 1996 Skylark with a 4.3L engine. Upon start up engine idle fluxuates up and down. It does this for a few minutes then levels off to a normal idle while the engine is warm. When the engine gets completely cold it acts up again. If I try before engine is warm it spudders leaving me to pump the accelerater to prevent it from dying. Can somebody give me an idea or two of what to check?? I am thinking automatic choke????
Old 12-26-2005, 02:48 PM
Lady Suhada Lady Suhada is offline
Our car is having the same problem. It's not low on gas. lol Any ideas?
Old 12-27-2005, 12:06 AM
Puffnstuff's Avatar
Puffnstuff Puffnstuff is offline
Send a message via ICQ to Puffnstuff
Re: skylark idles rough upon start up
Have you checked for a vacuum leak? Look at the hose to your pcv valve and make sure it's seated on the valve and the valve is seated in the valve cover. Mine came loose once and it ran rough and stalled until I discovered the hose.
06 Toyota Tundra Double Cab
Old 12-27-2005, 08:49 AM
Smile
Thanks for the tip! I'll check it right away.
