Old 11-25-2002, 11:36 PM
AnGeLoBBoy AnGeLoBBoy is offline
Send a message via AIM to AnGeLoBBoy
Thumbs down Exhaust Noises??
I have a Sebring Exhaust that is simply wonderful, but sometimes it makes a high pitch "rattling" sound instead of that deep sound we love to hear from exhausts. It only happens when i start off fast. I don't know if it means too much air is leaving the exhaust because I have 2.5" piping form headers to exhaust. If someone can suggest on what this sounds is I would like to know because i would like to find a way to change it if possible. Thanks ahead of time.
Old 11-27-2002, 03:58 PM
crxlvr's Avatar
crxlvr crxlvr is offline
Slowest Automatic Civic
Send a message via AIM to crxlvr
if its rattling under hard acceleration, its prolly just a loose bracket, check to see if the brackets are welded tight and its not vibrating off the frame of the car.
Stable Of Cars I have Owned:
1991 Honda CRX
1990 Oldsmobile Cutlass Supreme
2003 Honda Accord
1998 Chrysler Concorde
2007 Honda Civic
1997 Toyota Camry
1995 Saturn SC2
1996 Ford Taurus
1991 GMC Sierra
2002 Daewoo Leganza
1999 Dodge Ram
2007 Honda CR-V
2003 BMW 325i
Old 11-27-2002, 04:29 PM
I''m not sure if it's a bracket, because it's only during hard acceleration and it sounds like a "crackling" sound and not a "humming" like those deep exhausts. It has to be something with the air flow because i just installed a whole new exhaust system with piping and it did it before as well. Any suggestions, thanks ahead of time.
Old 11-28-2002, 12:35 AM
thewoahna's Avatar
thewoahna thewoahna is offline
Send a message via AIM to thewoahna
I think I know what you are talking about. I get some kinda noise that sound sorta like what you said. It only makes the noise under hard accel. till the exhaust gets nice and hot, then it stops. I just learned to live with it after getting sick of trying to figure out what it was.
Whenever at a loss of words, "Woah Na!" will suffice....
AOL IM: WoahNa316
Click here for some of my car pics/stats
Old 11-28-2002, 02:48 AM
civickiller civickiller is offline
Send a message via AIM to civickiller
most high flow exhaust do that. like greddy power extreme, racing medallion, all the bomb series. but like the other greddy exhaust, sound deep throaty, also thermal sounds deep throaty.
Old 11-30-2002, 10:56 AM
Frostbyte Frostbyte is offline
Send a message via ICQ to Frostbyte
I have a Greddy Power Extreme and it is hella deep and throaty and hella quiet until I put the high flow cat on there now it is deep and throaty when idle and now when I floor it, it is high pitched.
1989 s13 Fastback
Tein HE coil-overs
sr20det swapped!
JIC Magic Front and Rear Strut Bars
Slotted and Cross-drilled Rotors
S/S Brake Lines
Pivot Lazy eye controller
Blitz LM Intake
Blitz D1 Spec Turbo Timer
Soon to come:
Sard 550cc Injectors
Blitz Nur Spec Exhaust
Blitz Down pipe
HKS FMIC
http://www.driftmonkey.com (Part Owner)
Old 11-30-2002, 12:49 PM
strodda strodda is offline
that might be the problem then. i got the same results after i put the highflow cat in.
exhaust noise AccordCE8 Europe 13 05-30-2004 06:12 AM
Exhaust Noise bez Forced Induction 7 02-23-2002 10:19 PM
NZ Police to track exhaust noise levels Chilla General Discussion 59 01-19-2002 03:55 AM
Intake/Exhaust Noise? bobl Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 2 05-22-2001 10:37 AM
