Old 11-25-2002, 07:18 PM
Kunundrum's Avatar
Kunundrum Kunundrum is offline
Send a message via ICQ to Kunundrum Send a message via MSN to Kunundrum
B18A Questions
Alright, I found a B18A localy for 750$ (cnd) for the engine, transmission and clutch. ( no distributors, no starter) I can get the wire harness and ECU though for an other 100$
now other than B-series mounts, what else would I need ?
2012 VW Golf 3 Door Automatic (Company Car)
2011 VW Golf Wagon 5 speed (Company Car)
2010 VW Jetta 2.5 Automatic (Company Car)
2009 VW City Jetta 5 Speed (Company Car)
2009 VW GLI 6 Speed (Company Car)
2008 VW Jetta 2.0T 6speed (Company Car)
1999.5 Audi A4 Quattro Sport 1.8t (Chipped 1.0 bar) Sold
1990 CRX Si (Built B17a) - Stripped and Crushed
1988 CRX Si -- Stolen
1990 Civic Cx -- Sold
1990 Civic Si -- Parted
1989 Civic dx -- Sold
Old 11-25-2002, 08:02 PM
MyFirst4G's Avatar
MyFirst4G MyFirst4G is offline
Send a message via AIM to MyFirst4G
shift linkage, unless you can weld..... but its better to get shift linkage.....
88 DX Hatch SOLD!
90 Si Hatch Wreck'd :
Done parting out.. Shell is going to fire dept soon to get roof chopped off for some kind of drill.. wait for the movie!!
96 Saturn SL2:
Daily Driver untill 91DX is running!
91 DX Hatch:
Its gonna be Painted CL Type S Grey w/ WW RS kit from 90 Si and JDM CRX front end conversion... Powered by a Turbo'd GSR Motor..... Loot is on the way!!
Official 4th Gen OG
Hype Race Crew
Old 11-25-2002, 08:04 PM
Jmunk Jmunk is offline
Send a message via AIM to Jmunk
Shift linkage, you need to modify your exhaust to accept the header from the B18a, Axels. Thats about it if you get the wire harness and ECU. While the motor is out you may want to do a timing belt, water pump, clutch and make sure that all the seals are good.
Old 11-25-2002, 08:07 PM
Kunundrum's Avatar
what axels and what shifter linkage.
I was planning on doing a Mild build on the engine and a visual inspection of the transmission.
Old 11-25-2002, 08:08 PM
Kunundrum's Avatar
oh yeah any B series header will fit it right ?
Old 11-25-2002, 08:12 PM
For the shift linkage i would get the B18a and cut about 2 inches out of it and weld it up.....yes any B-series header will fit......get the B18a axels their the cheapest. Welding is the best part of a swap, you get to get custom on things. I refuse to buy motor mounts, i make my own....once again the welder comes into play. I always tell people yeah i can do anything i have a grinder and a welder.
Old 11-26-2002, 02:43 PM
Dweezil6969 Dweezil6969 is offline
if like most of us your not that good with a welde, www.hasport.com sells the mounts and the linkage you need. i'm looking at doing something like that in the spring.
`91 CRX DX Kind of moves
`90 CRX Si
Can also be found on:
XceedSpeed.com, MichiganCivics.com, and Zilvia.net
Old 11-26-2002, 02:45 PM
oh yeah make sure you get a header that's long enough. b16 and 18 blocks are different heights. and then you can sell me your mpfi
`90 CRX Si
Old 11-26-2002, 03:52 PM
Kunundrum's Avatar
i have a spare MPFI from my D16A6 I can sell,
(90 si) ECU, Intake manifold, injectors, Fuel Rail, Partial wire harness, The trhottle body is broken and you will need an resistor box.
how much is it worth to you ?
Old 11-28-2002, 09:19 PM
i don't know, i don't have a whole lot of cash, so first i'm gonna check the local yards and see what i can find, but i'll get back to you
`90 CRX Si
Another car stereo question Speculant Car Audio 11 08-18-2010 06:37 PM
2000 E150 question ZZT Econoline 1 11-25-2009 11:15 AM
exhaust question 89corollajoke Corolla/Matrix/Voltz 2 07-08-2009 11:22 AM
b18a question bubbaluv How-To's and Walk-Through's 1 11-21-2005 02:57 AM
b18a question alexngo '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 9 12-27-2003 04:24 PM
