Old 12-15-2003, 05:24 PM
alexngo alexngo is offline
b18a question
alright i got a 92 cx hatch... and im dropping in a Ls motor.... but the thing is that its a 90 ls... and the head is off a 94... everything should bolt up just fine right? yeah i got that whole package for 250 excluding tranny, and shift link... and which ecu would i have to use?
Old 12-15-2003, 06:04 PM
GScivic7's Avatar
GScivic7 GScivic7 is offline
Send a message via AIM to GScivic7 Send a message via MSN to GScivic7
Re: b18a question
you'll need motor mounts i think. I'm pretty sure that it won't just bolt in, but I might be wrong.
Empty Pockets Racing Member #1
Old 12-16-2003, 08:03 PM
kicker1_solo's Avatar
kicker1_solo kicker1_solo is offline
Send a message via AIM to kicker1_solo Send a message via Yahoo to kicker1_solo
yeah, motor mounts
2000 BMW 323IT
1954 Ford F100
With every post my penis grows smaller
Yakima Valley Truck Club Yakima Washington
Old 12-16-2003, 10:27 PM
94civic's Avatar
94civic 94civic is offline
Re: b18a question
you will also need axles, from a 99-00 si, 94-01 gsr, or 94-97 del sol dohc vtec. you can use any 94-95 obd1 ls,rs,or gs ecu. you can also chip a p28 to work with you app.
1994 civic ex - b16a sir2 w/lsd
too much to list
http://www.cardomain.com/memberpage/423478
Old 12-17-2003, 12:12 AM
Re: b18a question
so imma need custom motor mounts.. or can i use the ones from the 90 ls?
thanks for the help..
Old 12-18-2003, 10:01 PM
Re: b18a question
alright i purchased an obd0 ecu and head today... and i was wondering there wont be any problem installing it or anything right? everything should just plug n play w/ no problems?
Old 12-19-2003, 01:10 PM
94civic's Avatar
Re: Re: b18a question
you are going to have a problem. since your car is obd 1 you either need to convert the car to obd 0 or change the injectors and distributor to obd1 and get a obd 1 ecu.
too much to list
Old 12-20-2003, 08:46 PM
alright thanks for the help
Old 12-21-2003, 07:34 AM
jcrx jcrx is offline
Send a message via AIM to jcrx
Re: b18a question
You're fucking yourself by buying the OBD 0 parts, they are usless to you. You need to keep the OBD I head, and everything that is attached to it, it will plug right in. Use the mounts that come with the motor, and get the rear bracket from a 3rd gen teg. Get the axles that were listed above, and put the motor in your car.
Old 12-27-2003, 04:24 PM
Re: b18a question
okay i replaced the injectors, distributor.. i got the si axles, and an si tranny from a 99... now how about the wiring harness and everything... would i have to get it altered or anything or just plug that hoe up and run it
