Go Back   Automotive Forums Car Chat > Ford > Crown Victoria
Old 09-23-2007, 02:39 AM
greer2ed greer2ed is offline
2003 cvpi speedometer calibration
Hello, I recently upgraded my 2003 CVPI by putting a 3.73 gear in. I'm having trouble finding a way to recalibrate the speedometer. I took it to the dealership and they couldnt do it in the programmable parameters and the Superchips tuner cant do it either. Does anyone have any ideas/suggestions.
Thanks, Ryan.
Old 09-23-2007, 12:30 PM
way2old's Avatar
way2old way2old is offline
TOKEN HILLBILLY
Re: 2003 cvpi speedometer calibration
See if you can find the plastic gear that is for a 3:73 and change the gear on the VSS. Since it cant be programmed, you need to change the mechanical end of it.
Being way2old is why I need help from younger minds
The sooner you fall behind the more time you'll have to catch up.
HEY Y'ALL--READ THIS
Here are some of our old vehicles for sale.
Old 09-23-2007, 02:20 PM
reekor reekor is offline
From what i understand the 2003 and newer models dont use VSS or colored plastic speedo gears to derive vehicle speed and use the "OSS" output shaft speed sensor.
His, 96 Limited, 5.2 Magnum, Magnaflow CatBack System, HID Head & Fog Lamps, 242 T-case swapped , Rear Trac-Loc. Chrome grill added to match the wheels.
Hers, 96 Limited I6, 242 T-case, HID Head & Fog Lamps.
