Go Back   Automotive Forums Car Chat > Honda > Integra
Old 11-25-2002, 03:20 PM
CrazyFukr CrazyFukr is offline
Banned
Send a message via ICQ to CrazyFukr
shifting
when racing a 2nd gen integra should you shift at 5000rpm when you have peak torque, or 6000 rpm when you have peak horsepower?
Old 11-26-2002, 12:29 AM
b16a3sol b16a3sol is offline
shift at redline, thats what its there for.
Originally posted by honda720
i would never drive like that thats the pussy way to drive stick
Old 11-26-2002, 02:47 PM
Banned
hm
shift at 6500rpm ?
peak horsepower is at 6000rpm, which means that if you go to 6500rpm you will have the same horsepower as at 6000rpm, so you are just beating up your engine and burning gas going the extra 500rpm, right?
Old 11-26-2002, 05:34 PM
sameintheend01's Avatar
sameintheend01 sameintheend01 is offline
Send a message via AIM to sameintheend01
no cuz if u shift earlier, you will be in the lower part of the power band when you are in the next gear.
Old 11-29-2002, 11:40 PM
sameintheend01 is correct. there are two reasons why there is a redline. one is because if you go to warn you that you are reaching the limit in how fast the motor can turn without breaking. the other is to tell you when to shift so you can stay as much in the powerband as possible. use both reasons to your advantage.
Old 11-30-2002, 11:47 AM
THE4TH's Avatar
THE4TH THE4TH is offline
Send a message via AIM to THE4TH
it's the powerband you need to work with .... shifting at redline is your best choice for racing.. not only will it use the entire powerband for each gear.. but it will put you right into the powerband of the next gear, to avoid the low end sluggish pull.. works great with vtec.. in some instances.. you can redline it, and shift.. and still be in vtec.. a wonderful feeling..
S2000
Old 12-05-2002, 07:44 PM
xollins xollins is offline
Send a message via AIM to xollins
Where to shift...
Good question. I wish I could remember where I read a quite technical article discussing just this topic, but I do remember it saying that the particular optimal shift point depended on the specific car. Most cars benefited from being shifted at redline, but there were some that were better shifted at the peak torque (or at least prior to redline).
I am pretty sure the cars that would benefit by shifting prior to redline would be those with a rather flat torque curve (e.g. V8's).
I have an ITR and I am convinced that with it (and probably any other Honda/Acura) you are best to shift at red line which keeps the car in the "VTEC" rpm range when entering the next gear.
Hard Shifting 2-3, no-shift 3-4 Geo99M6z C/K 7 05-26-2012 09:45 AM
04 impala Shifts Hard when Hot, P1811,shifts hard,jerks chevymandan Impala | Impala SS 3 10-09-2011 04:42 PM
Translab tl-175 Shift Kit or other shift kits for 3000gts 97mits3000gt 3000GT/Stealth 1 03-08-2004 11:50 PM
96 Jimmy 4wd shift motor/shift module Llogoaero Jimmy 4 12-09-2003 11:54 AM
burst of thrust/ hard shift when auto tranny shifts into second gear ERIKbronx Maintenance 6 04-22-2002 12:36 PM
