Go Back   Automotive Forums Car Chat > Mercury > Grand Marquis
Old 09-17-2007, 10:13 PM
hanssolo hanssolo is offline
2000 model, A/C compr. wont run
The compressor won't come on. The car has 27k miles and the system is charged. Fuses are good. ???????
Old 09-18-2007, 07:32 AM
way2old's Avatar
way2old way2old is offline
TOKEN HILLBILLY
Re: 2000 model, A/C compr. wont run
How about the relay? Or the low pressure switch? Is it full of refrigerant??
Being way2old is why I need help from younger minds
The sooner you fall behind the more time you'll have to catch up.
HEY Y'ALL--READ THIS
Here are some of our old vehicles for sale.
Old 09-18-2007, 01:54 PM
The owners manual shows no relays for the compressor. There is charge but I need adapters for my gauges to see how much. They keep changing the fittings every 5 yrs. - that does'nt help. I'll also put voltmeter on the compr. plug & check that.
Old 09-18-2007, 08:15 PM
way2old's Avatar
TOKEN HILLBILLY
See if this diagram helps you any.
Old 09-19-2007, 02:16 PM
Thanx Hillbilly, good diagram- I printed it. Also found site with owners manuals in Adobe. Anyway I got can of freon with a gauge in the hose and after dumping some in, the compr. clicked on so its real low. My next question is: can I charge in the drier/accum fitting? Its all I see on the low side for a fitting. The hi & low side valves had some pressure still so I don't believe theres any air in the system. How many ounces does this system hold?
Old 09-19-2007, 04:57 PM
way2old's Avatar
TOKEN HILLBILLY
Good deal solo. Your system takes 2 pounds 6 ounces if it is completely empty. I would use a thermometer to measure duct temperature and when it gets around 40 degrees F stop adding refrigerant. You need to add a little at a time and let it run a few minutes in between shots and moniter the temperature at the vents. The fitting at the accumulator is the charge port. Good luck.
