Go Back   Automotive Forums Car Chat > Engineering/ Technical > Forced Induction
Forced Induction Discuss topics relating to turbochargers, superchargers, and nitrous oxide systems.
View Poll Results: Best combo?
T3/T4 4 50.00%
T28/T4 4 50.00%
Voters: 8. You may not vote on this poll
Old 11-24-2002, 01:27 PM
Polygon's Avatar
Polygon Polygon is offline
The Red Baron
Send a message via MSN to Polygon Send a message via Skype™ to Polygon
Better sequential combo?
Which would you say is a better combo:
T3 T4 combo or T28 T4 combo.
I ask this since the T28 will spool faster than the T3 and the T4 will have spooled by about 3500-4000 RPM depending. What do you think?
Old 12-04-2002, 12:55 AM
Polygon's Avatar
The Red Baron
Gah, does nobody care? I want some input here! At least vote.
Old 12-04-2002, 03:59 AM
Self's Avatar
Self Self is offline
Send a message via AIM to Self
DEFINATELY the t28/t4 combo. t28 spools quite a bit quicker, actually and in a sequential setup quick boost is the ONLY goal with the smaller turbo. Don't need it to make a lot of power at all. Just needs to make whatever power it's going to make QUICKLY. Let the bigger turbo "do it's thang"
There's no replacement for displacement...No, not even a turbo.
Old 12-04-2002, 04:50 PM
hybridsol's Avatar
hybridsol hybridsol is offline
Send a message via AIM to hybridsol
depends on the T28 most are T-3 compressor wheels carved to fit in the stock .48 a/r T25 compressor housings. It effectively eliminating the diffuser section of the compressor housing. A little less than half of compression takes place there. all and all a t/3 t/4 combo is over 80% effective when utilized correctly. So you guys know where I stand T/3 T/4 combo all the way.
Old 12-05-2002, 10:43 AM
Polygon's Avatar
The Red Baron
Hmm, well that is quite interesting. I didn't know that, I guess you do learn something new everyday.
non sequential and sequential? feedthafire RX-7 3 07-18-2006 12:40 AM
sequential or non sequential which is better? kyrx7 RX-7 22 06-30-2004 11:46 AM
Relatively cost-effective SEQUENTIAL transmission Morpheus XIII 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX 3 02-26-2002 07:46 PM
Twin spark and Dual Sequential Ignition DAINTY Engineering/ Technical 5 01-17-2002 09:05 AM
