Go Back   Automotive Forums Car Chat > Nissan > Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35
Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 Excellent platform and the good ol' VQ30DE and VQ35DE engines.
Old 11-24-2002, 09:55 AM
MaximusGTR's Avatar
MaximusGTR MaximusGTR is offline
Sparkplugs?
Hey, I just thought of something, out of all the mods I have, I never changed my sparkplugs. Which are the best Sparkplugs for a 95 Max?
Old 11-24-2002, 12:31 PM
zeff789 zeff789 is offline
Send a message via AIM to zeff789
NGK Platinum plugs, you can pick them up at your local dealer
'96 Maxima (not many mods but hope to fuck that shit up!)
Old 02-04-2003, 01:15 AM
MaximaSEAE01's Avatar
MaximaSEAE01 MaximaSEAE01 is offline
Send a message via AIM to MaximaSEAE01
watabout those iridium splugs?
SHIFT_VQ35 SWAP
Old 02-04-2003, 03:00 AM
DiS's Avatar
DiS DiS is offline
Send a message via AIM to DiS
Most of the plugs tend to melt... The NGK platinum are the best ones for the maxima and other Nissan make cars. There are two types of NGK spark plugs. There is a "cold" & "hot" types. Cold type is ment mostly for winter time when you need a bigger spark to start the engine up. The hot is regular type for warm type of weather (thats if you live somewhere nice like California or Florida) otherwise cold type NGK is for all seasons. Hope this helps.
97 Nissan Maxima GXE
Auto Trans
Red Injen Racing Division CAI with K&N FilterCharger, Zero1Racing Front Strut Bar
DaRk GrEeN/Beiege Interior
Cleared out taillights/Clear fronts/rewired blinkers and sidemarkers, upgraded grounding...Check my Pics out on my homepage
New purchase BRAND NEW '03 Mazda ProtegE 5-spd
_________________________________________________
Maximum Respect To MaxiManiacs and all Nissan 0wn3r$
Old 02-04-2003, 08:55 AM
NJMAXSELTD NJMAXSELTD is offline
Not quite....
A cold plug is used if your boosted or running NOS. The spark is not as hot as the normal plug. If you ran a cold plug in the winter, it would probably foul out.
You run one step cooler in order to avoid detionation under boosted conditions. It has nothing to do with the climate your in.
It's either the stock plug, or one step cooler. You can't put a hotter plug in your car, it will cause detionation.
99 SE LIMITED - A few changes here and there but most of all SPOTLESS!
Old 02-04-2003, 10:30 AM
MaximusGTR's Avatar
Ok guys, so in my case I would get................?
"SHIFT_"
Old 02-05-2003, 07:36 AM
The stock NGK Platinum Plug
Old 02-05-2003, 10:14 AM
D-sta D-sta is offline
Send a message via AIM to D-sta
yup buy the stock NGK platinum plugs at www.foreignautoparts.cc They have pretty good prices.
1992 Maxima SE 5-Speed VE Power.
MODS:Stillen HI-FLOW Intake, Tokico Blue Shocks, Eibach Pro-Kit Springs, Stillen Brake Pads, Brembo Rotors, Clear Corners, Suspension Techniques Sway Bar Kit, 2002-2003 Front FSTB, ASP UDP, Warpspeed Performance SS Y-Pipe, Carsound Cat, Greddy SP Exhaust System, SPW Industries HID PLUS 7500K Kit, 2001 Anniversary Edition Shift Knob, Stillen Tie-Down Battery Bar.
Old 02-05-2003, 10:27 AM
MaximusGTR's Avatar
Alright cool, I'll get them for my next tune up
"SHIFT_"
Old 02-05-2003, 03:12 PM
eh?
ok so what advantages does this NGK platinum have over the denso irdium splug and vice verse? what spark plugs were being used in our maximas when we rolled out of the dealer?
SHIFT_VQ35 SWAP
Old 02-05-2003, 04:38 PM
DiS's Avatar
DiS DiS is offline
Sh!t Each day Im learning something new. Thanks NJMAXSELTD Today because of you I have learned about cold & hot NGK plugs. My friend who told me stuff in my post above is a dumb ass.
Auto Trans
Old 02-05-2003, 06:13 PM
bk2kmax's Avatar
bk2kmax bk2kmax is offline
Re: eh?
I haven't never really seen a test where one plug is going to necessarily give you any gains over the other, now certain plugs when used in conjunction with certain mods (ie turbo and hot plugs, whatever) will help in producing a hotter spark but not necessarily give you any true edge in increasing your 0-60/1/4mi times.
Besides every test I've seen done on certain plugs like Iridium or Denso has always been done with modded cars, so to say one plug gives you an advantage over another is not written in concrete.
By the way, it should read bk2k3Max, not bk2kmax.
Old 02-06-2003, 02:28 AM
shoo...
to add more fusion to this thread, i just found "silver center electrodes" from www.carboyracing.com ...watabout those silver splugs?
SHIFT_VQ35 SWAP
Old 02-06-2003, 08:13 AM
Re: eh?
NGK Platinums on every single one of them.
Old 02-07-2003, 10:40 PM
xXx to de MAX xXx to de MAX is offline
Send a message via AIM to xXx to de MAX Send a message via Yahoo to xXx to de MAX
Just tell them you wanta NGK, one of my good friends is a Nissan Specialist, went to Nissan school and is a master tech, and told me to make suer i got NGK.
xXx
Rear Sparkplugs 3.3 Liter V6 backyardmech Caravan | Voyager 19 06-10-2007 09:27 PM
Sparkplugs fialdj Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail 6 02-18-2003 05:14 PM
Changing sparkplugs Rampicatore General Discussion 1 05-22-2002 02:12 PM
What Sparkplugs do you use or want to get? Cmotif Impreza/9-2x/Outback Sport 1 05-18-2002 03:28 PM
Oil on my sparkplugs d0qtrx Accord/TSX/Accord Hybrid 4 03-11-2002 07:08 AM
