Old 11-24-2002, 08:44 AM
kidcrook kidcrook is offline
Send a message via AIM to kidcrook
My Car won't start...
I went to start my car yesterday and it would not happen. I smelled a little smoke and it clicks when I turn the key. There is plenty of power from the battery b/c the lights work, radio, etc. I am 200 miles from home and don't know anyone in this area who could fix it. What can I do????
Old 11-24-2002, 10:20 AM
Could someone please help me? I need to get home by tonight and there seems to be no hope in sight for a service center on a Sunday. Does anyone have a suggestion of what the problem could possibly be? This means a whole lot to me and any type of help would be greatly appreciated.
Thanks.
Old 11-24-2002, 12:59 PM
grasshopper grasshopper is offline
i'm the last person to ask but i'm sure most on this forum would say that click could be related to your starter solenoid, i'd check connections there to make sure thats the culprit or not. it may be bad or you just need to clean up rust and corrosion off the connections.
Old 11-24-2002, 01:07 PM
forgot to mention...what smoke are you smelling...anyways, also.. it could be the starter motor thats bad as well, if you hear a LOUD click, or nothing at all. be darn sure your lites and radio ect. are fine and nothing dims significantly. if it is your startermotor try shaking/ tapping it to get it off the "bad spot" make sure the ignition is off, if its standard tranny, try putting it in gear and "rock" the car back and forth a few inches to move the starter motor off its "bad spot" but be advised it wont work all the time, so if you do get it running using this method, better not turn that bad boy off.
Old 11-24-2002, 02:57 PM
Deakins's Avatar
Deakins Deakins is offline
Guess that AAA+ membership doesn't seem all that expensive now
The ringing of the division bell, have stopped...
AF User Guidelines
Originally a Radiator Fan Problem, Now Car Won't Start fiskee '91 - '96 2 09-09-2009 12:17 PM
Please Help! 95 3.4 Won't Start No Spark elvisnut F-Body Problem Diagnosis 9 04-09-2009 03:20 PM
Gauges start jumping, lose power steering, car won't start for 5-10 minutes jonlake5 Cavalier Problem Diagnosis 1 06-18-2008 02:11 PM
530 doors won't unlock, car won't start bera1985 5 Series 1 12-07-2004 03:23 PM
1996 explorer factory alarm starts for no reason and then car won't start crashw Explorer | Explorer Sport Trac 2 06-15-2004 12:04 AM
