Go Back   Automotive Forums Car Chat > Toyota > 4Runner/GX470
Old 09-13-2007, 10:46 PM
vandok13's Avatar
vandok13 vandok13 is offline
Axle seal
1988 4runner, 22re. Rear Axle seal went and leaked oil into my drum and all over my new brake pads. Do i have to get my rear axle seals machine pressed in and out?any help would be great thanks? and if i dont how do i get too the axle seals?
Old 09-15-2007, 06:39 PM
vandok13's Avatar
Re: Axle seal
I have to get the exterior seal pressed because of the bearing but not interior seal on the housing for anyone with same problem
Old 09-15-2007, 08:51 PM
Brian R.'s Avatar
Brian R. Brian R. is offline
Resident Chemist
Send a message via Yahoo to Brian R.
Re: Axle seal
You should be able to tap it in with a suitable diameter piece of pipe and a hammer.
Forum Guidelines:http://www.automotiveforums.com/vbulletin/guidelines.html
"What we've got here is a failure to communicate"
Old 09-16-2007, 07:26 PM
fourwd1's Avatar
fourwd1 fourwd1 is offline
AF -Advisor
Re: Axle seal
If it's the inner seal, you have to pull the axle shaft/drum brake assy.
Basics:
First disconnect the brake line and plug it.
There are 4 bolts on the back side that hold it onto the axle housing.
Slide the axle shaft assy out.
Pry out the seal with a screwdriver, etc.
Install the new seal, a socket the size of the seal makes it easier to tap it in.
84 4Runner - ARBed 5.29s F&R, 4.7 & 2.28 t-cases, Chevys, AP x-over, BudBuilt x-member, 2" drv trn lift, 36" TSLs, 30 spline Longs
80 something p/u - Buick 231 V6/TH-350 trans, Holley 4 bbl, Weiand intake, dual batts, dual tanks ...
89 4Runner - stock
2000 Isuzu Trooper + 2010 Sonata
