Old 10-20-2002, 01:32 AM
bc4g bc4g is offline
my tach dosent work when the lights are on
I have my tack wired pos. to pos.battery neg. to neg side of the battey and for the light I wired it to my parking lights well I disconnected some old speaker wire from the pos. batt. and the tach pos. came off and then touched pos. again and now my tach only works when the parking lights are off and the light on tack dosent come on at all PLEASE HELP ME
Thank You
Chad
B C kit
motegi 15's
tenzo R seats
3'' exhaust 5'' tip
Old 10-20-2002, 02:47 AM
Cjz89civic's Avatar
Cjz89civic Cjz89civic is offline
AF Premium User
Send a message via AIM to Cjz89civic Send a message via Yahoo to Cjz89civic
If I'm correct there should be 4 wires that run off you tach. Right? Ok if so the colors are different on all tachs. It sounds like you have the feed wire (the coil one) going to your dash lights. and the pos one to power the unit going to your coil. JUST recheck your wiring as Im writing this I know what Im saying but it dont sound right. sounds to me like ya got the wiring messed up.
Old 10-20-2002, 11:15 AM
MyFirst4G's Avatar
MyFirst4G MyFirst4G is offline
Send a message via AIM to MyFirst4G
yea, wireing is probably messed up, i know with my friends Autometer Tach, there are 4 wires, red=positive, black=ground, green=to dizzy, and yellow=to parking lights...... Thats how we have it and it works perfectly....... what brand is yours?
88 DX Hatch SOLD!
90 Si Hatch Wreck'd :
Done parting out.. Shell is going to fire dept soon to get roof chopped off for some kind of drill.. wait for the movie!!
96 Saturn SL2:
Daily Driver untill 91DX is running!
91 DX Hatch:
Its gonna be Painted CL Type S Grey w/ WW RS kit from 90 Si and JDM CRX front end conversion... Powered by a Turbo'd GSR Motor..... Loot is on the way!!
Official 4th Gen OG
Hype Race Crew
Old 10-20-2002, 11:19 AM
Yea I have four wires pos. neg. coil wire and light for tach which I tapped into my parking lights everything worked fine until I touched that pos wire to the battery after it came unhooked I reconnected it while still grounded. The tach works when the headlights are off but when there on I get no reading
Thanks
Chad
B C kit
motegi 15's
tenzo R seats
3'' exhaust 5'' tip
Old 10-20-2002, 11:21 AM
Oh yea its a sunpro
B C kit
motegi 15's
tenzo R seats
3'' exhaust 5'' tip
Old 10-20-2002, 11:22 AM
MyFirst4G's Avatar
try disconnecting the wire that turns on the light for the tach, and if it works, you have a tach with no light! now, try follow this wire and make sure its not burnt up anywhere, cause that might have happened, if it did, replace the wire, or cut it where it got burnt and wire an extension on there, and try again...... i hope that made sense!
88 DX Hatch SOLD!
96 Saturn SL2:
91 DX Hatch:
Official 4th Gen OG
Hype Race Crew
Old 10-20-2002, 11:29 AM
Thanks for all the help. I also have two autometer gauges with just the lights wired into the tach so they all ran off the same line I'm gonna go check the wire Thanks guys
Chad
B C kit
motegi 15's
tenzo R seats
3'' exhaust 5'' tip
Old 10-20-2002, 11:30 AM
MyFirst4G's Avatar
no prob man, hope it all works out good, you should get a thicker gauge if you are gonna run other gauges off the same thing......
88 DX Hatch SOLD!
96 Saturn SL2:
91 DX Hatch:
Official 4th Gen OG
Hype Race Crew
Old 10-20-2002, 10:05 PM
Ok I cut the wire that went to my parking lights that powered the light on my tach and now it dosent work at all
B C kit
motegi 15's
tenzo R seats
3'' exhaust 5'' tip
Old 10-20-2002, 10:08 PM
MyFirst4G's Avatar
the tach doesnt work at all? like ZIP? take off the wire for your light, and see if the tach works without the light...... contact the manufactur, u might have a defective tach.... i dun know what else to tell ya!
88 DX Hatch SOLD!
96 Saturn SL2:
91 DX Hatch:
Official 4th Gen OG
Hype Race Crew
Old 10-20-2002, 11:38 PM
Dark Syde Racer Dark Syde Racer is offline
DID YOU HOOK your light wire to the parking lights (and do it backwards) so taht when they are off the light is on and when the lights are on the tach is off? might be somthing as simple as that
1990 GS-T
Mods:
HKS intake
16G turbo (18psi)
ALL FREE MODS
full 2.5 exhaust
S-AFC controller
HKS turbo timer
HKS ECV II
3in Custom intake pipe
Chipped ecu
short shifter
Cyclone motor
5.6 LCD screen
PS2/DVD player
Eclipse CD player
JBL speakers
Fosgate HX2 12
1991 GS-T (NEW PROJECT)
1998 Pontiac Trans Sport radiator fans only work when the AC is turned on amikayla Montana/Montana SV6 1 06-01-2010 12:25 PM
1993 GAS Gage Dosent work Or The Tempature Gage magna152k2 Caprice 4 03-20-2008 09:36 PM
instrument lights go off when outer lights are turned on!! japalm419 Lumina 2 06-04-2006 10:49 PM
Break Lights on when Head lights are on nkgy Corolla/Matrix/Voltz 1 05-01-2004 08:38 PM
signals only working on one side when dash lights are on BlueCivic83 '88 - '91 Civic | CRX | Wagon | Shuttlee 0 01-16-2004 10:00 PM
