Go Back   Automotive Forums Car Chat > Mercury > Grand Marquis
Old 09-10-2007, 06:50 PM
kdark kdark is offline
Help with beeps
Hey guys, i'm new around here and just have a quick question:
I have a 1990 Mercury Grand Marquis that beeps from the dashboard usually in 7 sets of 5 beeps. Talk about annoying. It doesn't come over the stereo or anything like that, it sounds like its actually coming from behind the dash. I tried googling it (How I found these forms) to no avail, does anyone know why it would be doing this, or how I can stop it? I brought it to a mechanic and he said he couldn't even find where it was coming from. My dad thinks it has something to do with the airbag being disconnected, but I don't see why that would be.
Any help would be greatly apperciated.
-Ken
Old 09-10-2007, 08:19 PM
way2old's Avatar
way2old way2old is offline
TOKEN HILLBILLY
Re: Help with beeps
your dad is correct the series of beeps means the airbag is not working properly
Being way2old is why I need help from younger minds
The sooner you fall behind the more time you'll have to catch up.
HEY Y'ALL--READ THIS
Here are some of our old vehicles for sale.
Old 09-10-2007, 10:13 PM
Re: Help with beeps
Is there any way I can stop them sans bringing it in to have whatever is wrong fixed? I've already dropped a good bit of money into this car (it's been for sale for a while, just trying to keep it running till it sells) and i'm try to avoid any more.
Old 09-11-2007, 02:43 PM
way2old's Avatar
TOKEN HILLBILLY
Re: Help with beeps
Does the ABS light in the dash come on when the key is turned on? If not, replace the bulb.
Old 10-17-2007, 01:27 AM
moparvwfreak moparvwfreak is offline
Re: Help with beeps
sounds like the beeps from the airbag module. at least thats what the factory service tells me.
dodges, dubs, chevys and now fords. i am a glutton for punishment.
Old 11-07-2007, 11:39 PM
92mercmadman 92mercmadman is offline
Re: Help with beeps
yep airbag take it to the dealer never mess with airbags unless your trained...you really can die. no lie.
_Newest Project_
1992 Mercury Grand Marquis
-Cold air Intake
-Powdercoated Black Rims
-Lowered 2"
-Flowmaster duals
-Interceptor Motor
-Aluminum Driveshaft
-Limited Slip Rear End
-Last Dyno 349rwhp
-Last 1/4 run = 13.26 @ 134
Old 11-10-2007, 03:48 PM
dugan50's Avatar
dugan50 dugan50 is offline
Authorized Vendor
Re: Help with beeps
Hi Ken:
Your airbag system is inoperative. The airbag will not protect you in an accident. You need to know this before we go any further. You should have the system repaired properly...it's not an expensive system for that vehicle. If you want to know what components you may need to repair the system, you can visit our website @ www.Airbagsolutions.com.
The tones you hear are actually fault codes for the airbag system. The system is designed to flash an airbag light when the system fails, and if the light fails, the failsafe system initiates a tone system in the diagnostic monitor. Yours is located unde the dash. It's a blue box, about 6"x4"x1". If you find it, you can disonnect the 2 gray connectors and the tones should stop.
I hope this was helpful to you. My information comes from years of experience in these businesses.
http://www.airbagsolutions.com http://www.stolenandrecovered.com
Airbag Service, Airbag Replacement, Airbag Diagnostics
Thank You,
Douglas Gan
Old 12-14-2007, 10:28 AM
Stale Trooper's Avatar
Stale Trooper Stale Trooper is offline
Re: Help with beeps
On my '99 CV, I had the same problem, replacing the air bag warning light solved the problem for about 97 cents.
Stale Trooper
'05 CVPI
(My '99 got wiped out with 238,513 miles on the clock, stupid woman driver)
It's White, with a black grille, a spotlight, and the butt is black. Need a picture? Thought not
Old 10-02-2009, 05:55 PM
tacomabobd tacomabobd is offline
Send a message via Yahoo to tacomabobd
Re: Help with beeps
I am having similar problems. My 1990 mercury's airbag light blinks nine times. Where can I find out what the codes mean? I have been to http://www.airbagsolutions.com several times and the information is too general and very expensive to join. Is there an ODB connector in these older vehicles and where is it?
Thanks in advance,
Bob
