Closed Thread Show Printable Version Show Printable Version | Subscription Subscribe to this Thread
Old 09-09-2007, 10:38 PM
bbullsj bbullsj is offline
high engine temp? and no oil pressure
i have a 1990 cavalier z24 with a 3.1 engine and 5 speed tranny. my engine temp it usually around 200 degrees. that sounds a little high to me. should i flush the cooling system and replace the thermostat? also my oil pressure gauge is maxed out. the only time it drops is when i'm taking off in first and i bog down the engine enough alsmot stalling it. when downshifting to come to a stop and the revs go up just under 3 grand i get a backfiring spiting sounds out of the exhaust. it doesn't sound very good and i'm wondering if it's a major problem or not. i bought this car 3 months ago and have only filled the tires with air, changed the oil and filter, and cleaned all 4 brakes and replaced the front pads, so other than that i haven't checked anything on the car.
Old 01-25-2008, 09:33 PM
anomaly_va_1976 anomaly_va_1976 is offline
Re: high engine temp? and no oil pressure
The factory thermostat opens at 195, and the fan cuts in at 220... 200 is normal.... oil pressure reading could be a bad sending unit.... you don't mention the engine size, but 3.1s typically read 60-80 idling cold and 30-40 idling warm....could also be a stuck bypass valve on the oil pump (not common, but possible)
Don't Worry What Others Think -
They Don't Do It That Often!
James Collier < [email protected] >
1992 Chevrolet Cavalier Z24 Convertible (3.1, 5-sp) *** FOR SALE -- SEE CAVALIER CLASSIFIEDS ON AUTOMOTIVE FORUMS.COM***
1993 Chevrolet Beretta (3.1, 3-sp auto)
1995 Mercury Marquis (Taxicab, i.e., breadwinner)
Old 01-25-2008, 11:18 PM
'97ventureowner's Avatar
'97ventureowner '97ventureowner is offline
Closed. Reason: resurrected thread.
Thought for the Day… Alcohol does not make you fat - It makes you lean... against tables, chairs, floors, walls and ugly people.
If a prostitute here in America loses her job to a prostitute in India , is that considered "outwhoring"??-Jay Leno
" A Good Thing To Know"
Closed Thread
