Old 09-08-2007, 01:19 PM
cargirl02119 cargirl02119 is offline
Question PLS HELP!!! 1990 Honda Civic CRX
I bought this one owner auto back in '03. It had been sitting in the cold and snow of the NE for a least a year. I keep her in excellant condition but because of the undercarriage rusting my gear shift cable ( the cable that allows you to put the car into gear) finally broke and I'm having a heck of a time replacing it!!! They said that they no longer make them!! Needless to say can't drive it if you can't put it into gear. I live in MA but if you can put me in touch or you have one please let me know. My jets are cooling fast!! She's much to good of a car to junk!!!! Waiting with baited breath!!!
Old 09-20-2007, 10:52 PM
wiseguy01's Avatar
wiseguy01 wiseguy01 is offline
Re: PLS HELP!!! 1990 Honda Civic CRX
well you can find the right parts supplier for the cable but after you get it i reccomend getting undercarriage sandblasted and rhino lined as fast as u can before u punch a hole through the floor board
Old 09-21-2007, 02:03 AM
thefooshmeister thefooshmeister is offline
Send a message via AIM to thefooshmeister
id ask this in the 4th gen section im sure someone has one..but i would just go to a junkyard and pull one from a civic or crx 1990-91..they only take about 5 mins to remove one..
thats weird that the gear shifter cable went bad cuz of it sitting..do you mean shift linkage or the cable??
98 Jetta GLX VR6-vroom vroom!!
91 CRX Si-R..busted..
Old 09-21-2007, 08:06 PM
wiseguy01's Avatar
the car is in the eastern united states and what they have is called snow and ice and the road crews use salt to get it off and the salt get on the undercarriage and rusts everything that is metal so thats why the cable broke rust got to it because of salt
Old 09-21-2007, 10:05 PM
no shit sherlock..i live in ohio..but your cable is higher than your engine..i dont understand how it went bad cuz of that..
Old 09-22-2007, 12:43 PM
AudioGuy93DelSol's Avatar
AudioGuy93DelSol AudioGuy93DelSol is offline
NA is Best!
Send a message via AIM to AudioGuy93DelSol
Moved accordingly.
Oil leak? What oil leak? That puddle under the car is just sweat from all that horsepower.
"How many NASCAR passes is that worth? 500?" (Schumacher passing Raikkonen)
Emily is amazing, and she messed with my sig AGAIN!
Old 09-23-2007, 10:24 AM
Christ Christ is offline
Send a message via AIM to Christ Send a message via Yahoo to Christ
ok, so you consider that if she's saying cable, it's probably an Auto-Magic car...
Being Auto-Magic, the cable(s) would be plastic coated... (I make similar cables at work all day long.)
Being plastic coated *to prevent rust and the like* it's pretty safe to say that one of two things happened.
1) The end of the cable that connects to the transmission failed, or
2) Something has come loose, and she hasn't actually researched the problem, is just assuming the shift cable is borked.
PS @ Foosh -- Wanna sell that Si-R?
