Old 11-20-2002, 04:07 PM
giordano giordano is offline
best chrome paint?
what's the best chrome paint to use for pipes, rims and trims? i'm using modelmaster chrome silver, but for some projects it doesn't do the trick. need your opinion on this please!
thanx in advance.
gio
Old 11-20-2002, 04:10 PM
ales's Avatar
ales ales is offline
Forza Schumacher
I use either BMF foil or silver paint from Tamiya X-11 marker, although the latter is completely not resistant to touch.
Old 11-20-2002, 04:13 PM
hiver77's Avatar
hiver77 hiver77 is offline
Ales, I tried the X-11 using airbrush and I didnt get the kind of shine I was looking for. It's more like metallic color with visible flakes.
Do you have better luck with it?
In the finishing stage:
Old 11-20-2002, 04:22 PM
ales's Avatar
Forza Schumacher
I'm talking about the X-11 paint from the Tamiya marker. And I just use a paintbrush for that. Also Plasti-Lote should have chrome paint, I've never used that, but Guiddy has and swears by it.
Old 11-20-2002, 04:41 PM
MaukaRunner MaukaRunner is offline
Send a message via AIM to MaukaRunner
Has anyone tried Alcad?? I've only heard good things, other than price, about it.
Old 11-20-2002, 04:52 PM
freakray freakray is offline
AF Modelrater
Alclad is the best way to get a true chrome look finish from a paint.
For more information on it, go to www.alclad2.com and it is available for purchase from www.squadron.com
ModelMaster makes metalizer paints too, but their chrome is not as good as the Alclad stuff.
Ray
AF User Guidelines
Old 11-20-2002, 05:09 PM
daggerlee's Avatar
Alclad II chrome is the one that gets recommended the most. You'll need to spray it over a gloss black enamel surface.
For an alternative, you can try the many chrome metalizers offered by automotive lacquer companies like Plastikote, Duplicolor. It's a pretty good match, if not exactly.
Dan
Old 11-22-2002, 11:00 AM
thanx for the reps. i was thinking of using those automotive chrome paints, but i wasn't certain cause it might melt the plastic. so will it? heard 'bout alclad too, but it's somewhat expensive. is it really worth it though? well, i've tried that tamiya maker imo it seems too grainy and it still doesn't look right.
daggerlee,
what do you mean? "You'll need to spray it over a gloss black enamel surface." so you mean if i painted a car red i have to spray black over the area i'm planning to chrome?
Old 11-22-2002, 11:34 AM
AF Modelrater
Alclad chrome metalizer requires an undercoat of gloss black to get the brilliance out of the chrome.
If you look at the alclad link I posted above there is a full description of how to use it there, as well as examples of what it will look like when finished.
Ray
AF User Guidelines
Old 11-25-2002, 11:23 AM
ok thanx!
Old 05-28-2009, 12:58 PM
Modulus Digitalis Modulus Digitalis is offline
Re: best chrome paint?
Hi all,
Is it possible to use chrome paint on aluminum? If so please give me some suggestions. I'm looking for the right balance between quality and cost. It would also be good if there was enough paint per can or whatever to cover a lot of surface area.
Thanks!
David H.
Old 05-28-2009, 03:10 PM
matador88's Avatar
matador88 matador88 is offline
if you need only some minor brush painting then testor / model master chrome syntethics email is great
Old 05-28-2009, 04:09 PM
360spider's Avatar
Wow, a thread from 2002!
Alclad should do the trick for you.
ItalianHorses.net
Old 05-28-2009, 11:37 PM
Scuderia. Scuderia. is offline
This stuff is awesome and better than alclad, although it isn't a paint.
Take note of the warning though if you are a bit ham fisted.
http://www.hlj.com/product/WRK00251
Old 05-29-2009, 02:01 AM
TRBJ TRBJ is offline
Send a message via MSN to TRBJ Send a message via Skype™ to TRBJ
i bought one of those in M model shop in singapore.. its damn good, damn easy to apply, tho it produces a darker shade of chrome than alclad.. but then its FREAKISHLY fragile as u cannot touch it AT ALL coz once its touched, the surface gives out this ungly finger print and so much of the chromed is stripped away
sylvia
Best *brushable* chrome paint? racer93 Car Modeling 9 02-12-2011 12:01 AM
Some good chrome paint! ratdat Car Modeling 6 11-02-2003 11:22 PM
Whats the best chrome paint? BOOSTD Car Modeling 8 08-08-2003 06:24 AM
Chrome Paint RyanGiorgio Car Modeling 4 12-18-2002 08:42 PM
Chrome Paint mole Car Modeling 1 01-24-2002 09:52 AM
