Old 11-19-2002, 04:41 PM
hondacivic4drlx's Avatar
hondacivic4drlx hondacivic4drlx is offline
Send a message via AIM to hondacivic4drlx
having problem with a zc swap in a civic dx
i installed a zc motor in a 88 civic , i converted all the wiring harness for a multiport injection and it start up , but it gives codes4-crank angle sensor and code 10 dont know it idels iratacly as well as injector #1 not dumping fuel, it wont stay on and if it does it idels like 100 -300rpm constantly then it will just die out, has anybody done this swap and have this accured to them please help!!! or any suggestions thank you.
Old 11-20-2002, 09:03 AM
91civicDXdude's Avatar
did you make sure to swap the distributor with one that came from an MPFI equipped vehicle and change the ECU as well?
problem with 98 civic with jdm b18c evilscort93 JDM Motor & Parts info/chat 3 08-18-2005 05:55 PM
Having problem with 92' Chevy Cavalier - Please Help feben Cavalier 2 05-10-2004 06:21 PM
Does any of you (p11) have problems with rear calipers? jprimera Engine 8 01-05-2002 01:28 PM
anyone have problems with purolator oil filters? u4ikstilz Engine 12 10-26-2001 07:34 AM
having problems with your chrysler??? olds88 Engineering/ Technical 3 08-26-2001 08:42 AM
