Old 08-29-2007, 11:21 AM
teszion's Avatar
teszion teszion is offline
WIP: Fujimi ferrari F40 LM (test ver.flat-black)
Hi. all.. next works is Ferrari F40 perfectly like one out of many. this kit is fujimi. not open rear cover compare tamiya F40 is open rear cover. attitude is superiority fujimi.
Parts is 95ea.(not use parts include)
contents parts.
body.
compare tamiya f40..rear wing width better wide fujimi.
wheel...
LM(lemans) type slick tire.
rear tire and wheel.
wide-range tire.
add parts for LM.
wander part.
when order 'caution' steer parts damage from package press.
clear parts...
normal clearness.
package box pressed shipping damage. before crack parts.
PE...
other side PE.
decal.....
seat belt.(but seat parts is molded )
assembly maual.
to be continued..
http://ferrari-f40.tistory.com
Old 08-29-2007, 11:30 AM
teszion's Avatar
Re: WIP: Fujimi ferrari F40 LM (test ver.)
surface can coat #500 and then flat balck coat.
remove plate silver coat.
once again lacquer thinner soak then stripped thin coat film.
both sides tape is PE attach.
once more mask tape then 0.5mm pin vice drilling hole. rivet is Model factory Hiro products.
antenna is brass line 0.3mm.
simple interior.
engine room completed.
Resin recasting fire extinguisher. original parts is SAKATSU products.
interior completed.
Old 08-29-2007, 01:07 PM
Martin S's Avatar
Martin S Martin S is offline
Very nice build so far !
Especially since I'm building one in scale 1:16. Looks good in black !
Latest progress:
Ferrari F40 LM Fujimi 1/16 and Porsche 959 Fujimi 1/16
Finished:
1940 Ford pickup and Lotus Super Twelve
Old 08-29-2007, 10:43 PM
MidMazar's Avatar
MidMazar MidMazar is offline
Looks sweet, can't wait to see it done. Its nice to see PE in kits, tamiya should start doing that since each of their new kits are about 50 bucks.
In Progress
Old 08-29-2007, 11:29 PM
924_CarreraGTS's Avatar
924_CarreraGTS 924_CarreraGTS is offline
Nice fast progress!! Looks great, the F40 is an awesome car. Usually I would not be happy with the molded-in engine but you can hardly tell once all the manifold parts are in place. Good work so far.
Alex
Old 08-30-2007, 07:35 AM
godfather23's Avatar
godfather23 godfather23 is offline
Nice progress. I have seen one of these being built here. Great effort to enhance the poor detail on the kit.
The shot from the back looks awesome!
Recently finished Projects:
Porsche 911 Carrera RS 3.0
Current Projects:
Old 09-01-2007, 05:24 PM
beaver63's Avatar
beaver63 beaver63 is offline
Perfect jobs Awesome
Old 09-01-2007, 08:55 PM
jmwallac's Avatar
jmwallac jmwallac is offline
Cool looking car and wicked fast build! Two questions:
1) In the first picture is that the parking brake on the rear rotor? Why would a race car have a parking brake?
2) Did you pour straight lacquer thinner over the rim to remove the coating? I've used it to remove paint and it always seems to make the plastic soft and gooey. How did you do this without ruining the part?
Thanks
Recently completed projects:
Old 09-02-2007, 01:03 AM
teszion's Avatar
Thanks
1.i guess this models is a trial product for that reason. a section parts intact use.
fujimi is variation prototype change model kit.
(rear fender slit no.5ea/rear window slit no. column10 row 2/rea view mirror mount window..etc)
a mold design difference tamiya. tamiya mold is middle change model.
everything both maker not late model. ( 1/18,1/12 kyosho diecast model and 1/8 pocher model is unique late ver.)
by example fujimi 1/16 f40 a lot models.
fujimi 1/16 F40 gt model.
fujimi 1/16 F40 street ver.
maybe maker commit a fault?..
2. thinner of strong toxicity use then melt plastic.(do not use industrial thinner)
recommendation always use hobby maker thinner.(ex: gunze leveling thinner is high-quality articles)
Old 09-02-2007, 01:49 AM
cyberkid's Avatar
cyberkid cyberkid is offline
I have a tub of bleach that I use specifically for removing kit chrome. Takes it off within 20 minutes. Just put the parts in and let it soak. No scrubbing is needed. Will not harm the parts what-so-ever. Even leaves the clear varnish untouched.
HTH
Steve
Please read the following linked articals before posting a question.
Once you have and still have questions, try to post your questions clearly.
This will make a lot of people's blood pressure drop back to normal, including mine.
NEW TO THE AF MODELLING FORUM? PLEASE READ THIS FIRST
AF Car Modeling Tutorial, How-To and Product Review Depository
AF Car Modeling Frequently Asked Questions [FAQ] - * Look here first! * ver2.0
And finally,I wish you all happy modeling
Old 09-02-2007, 01:25 PM
jmwallac's Avatar
HTH
Steve
I've found bleach to be much more effective than oven cleaner. Do most people take the clear varnish off? I've found that it makes for a nice smooth surface and usually leave it as is. Sorry for the thread hi-jack...
Old 09-02-2007, 10:17 PM
hirofkd's Avatar
hirofkd hirofkd is offline
Most of Fujimi's F40 kits are based on one of the prototypes, that's why there are some inaccuracies. If you want a correct rear window, Fujimi's F40 LM has the correct 11-slit one.
Hiroaki Fukuda
Old 09-03-2007, 02:39 AM
gionc's Avatar
gionc gionc is offline
Authorized Vendor
Great.
I guess the exaust would be straight, without muffler... 1 pipe for each side plus a thiny one for the westgate?
gio
Old 09-03-2007, 04:46 AM
cyberkid's Avatar
Don't know what most people do, but I just use the varnish as a primer.. Gloss black then Alclad2.
Old 09-06-2007, 07:03 AM
auw12's Avatar
auw12 auw12 is offline
Great works as always Mr. Kim! I'm happy to see a semi-gloss car from you so I wont be shocked again by the incredible shine~
