Old 11-18-2002, 07:12 PM
FourthGenHatch's Avatar
FourthGenHatch FourthGenHatch is offline
Send a message via AIM to FourthGenHatch
Unhappy My Spark Plugs drowned today...
Today at school I was cruising the auto building seeing if any sweet cars were around. I found a yellow ITR with the exact same rims I have, and there was a 5G Hatch with black rims and polished lip. Other than that was rice. So as I tried to leave I cranked the car and it started then died. It did this the other day but I thought it was water in the distributor cap or something. Apparently not. So first thing I did was check the plugs. They were all still in. So I pull the plugs from the head one by one. Almost all of the plug cylinders was filled with oil and some of the spark plugs were drowned in oil. So I was like ****. So using only paper towels from my trunk I managed to soak up all the oil then clean the cylinder walls and the plug tips. So after 3 cranks it started and I was able to drive it home. I got my Dad to drive me to Honda and I got new OEM NKG Spark Plugs and new Seals. I put them in and it started a little after that. TONS of smoke poured out from the oil I guess leaked down into the cylinder. It drove fine after that. However the next time I started it it wouldn't start until 2nd try. Hopefully it will all burn off that oil and it will be fine. But thats weak sauce...
http://www.fourthgenhatch.com
FOR SALE: Get this stuff out of my house!
-Stock hood (red) $30
-Stock Rear Spoiler (red) $30
-Stock mirrors $30/both
-Stock side front and rear side glass $30/piece
Old 11-18-2002, 10:58 PM
civic89dx civic89dx is offline
Send a message via AIM to civic89dx
wow, sounds bad, i hope it was just the seals to the spark plugs. good luck.
Old 11-19-2002, 11:36 AM
amy@af's Avatar
amy@af amy@af is offline
Traffic Directing Admin
Send a message via Skype™ to amy@af
yikes! update? how is it firing now? i found oil on the plugs in my a6. replaced the seals and the head gasket. when the head was off could see #1 cylinder wall was grooved. a6 is now in LX. pulled the plugs and found oil. pretty much it's gonna need to be bore out and bigger pistons....or junk it. moral of the story? i don't want to scare you but oil could be getting past your rings. how many miles does the engine have?
ami
"hi! my name is Lady, and i'm a HONDA-holic"
..don't make me send Setanta over in his Waambulance to give you an aloe tissue for your sensitive nose!
*~ ~> USeR GUiDELiNeS*<~ ~*
I <3 the G Ride ~*~ I <3 OLD SKooL
Old 11-19-2002, 03:00 PM
civickiller civickiller is offline
Send a message via AIM to civickiller
yeah if oils in there then its either the valve seals or rings. have you ever ran you car without oil before ? or does it have oil in there.
Old 11-19-2002, 03:51 PM
dfarres's Avatar
dfarres dfarres is offline
Send a message via Yahoo to dfarres
r there seals that go around the spark plugs on the valve cover? I did a little maintenance on my wifes Accord & noticed that 2 of the plugs I pulled had oil in the hole of the valve cover. Do I need to replace the valve cover gasket or what?
1993 Civic Coupe EX
1997 Chevy Suburban LT
“It's all fun and games - Until someone loses an eye"
Old 11-19-2002, 10:21 PM
Like I said I put in new seals and plugs. Drives like a champ now
Old 11-19-2002, 10:49 PM
GTA's Avatar
GTA GTA is offline
Whee..
yes there are seals. they should come with when you buy a valve cover gasket set....at least they did when i bought one for mine
AF Bay Area Crew
RIP Melt
2008 Mitsubishi Lancer Evolution GSR
2007 Toyota Prius
I <3 and miss my 4g
Old 11-20-2002, 07:58 AM
Yes there are 4 seals, one for each plug. They attach to the underside of the valve cover so unless you looked under there you might have not noticed them.
Old 11-20-2002, 08:02 AM
Dark Syde Racer Dark Syde Racer is offline
had the same prob with my car when i got it...replaced valve cover gasket and the rings around the casing for the plugs..what ever the hell they are called lol its 6am i havent slept in 2 days im tired so let that one slide..but after i replaced those had no probs at all
1990 GS-T
Mods:
HKS intake
16G turbo (18psi)
ALL FREE MODS
full 2.5 exhaust
S-AFC controller
HKS turbo timer
HKS ECV II
3in Custom intake pipe
Chipped ecu
short shifter
Cyclone motor
5.6 LCD screen
PS2/DVD player
Eclipse CD player
JBL speakers
Fosgate HX2 12
1991 GS-T (NEW PROJECT)
Old 11-20-2002, 11:14 AM
dfarres's Avatar
Thanks 4 the info..... I guess I know what my next project is.
1993 Civic Coupe EX
Having 3.5L spark plugs in a 2.7L engine. Benjamin_2002 Intrepid 1 02-28-2011 05:19 PM
E150 5.4L Spark Plug Replacement leroge Econoline 1 04-19-2010 08:19 PM
Shot Out Spark Plug Today WheelerXp Cavalier Problem Diagnosis 2 01-04-2010 04:53 PM
spark plug analysis keilerstag Cutlass Series 1 06-29-2009 08:25 AM
spark plugs freakyfire05 ZX2 2 02-17-2009 11:03 AM
