Old 08-27-2007, 11:51 PM
low1971 low1971 is offline
Talking 454 in a Chevette?
So some budies and I have aquired a chevette and now have a 454 to put into it... will this work? We know that 350's have been put in and all, but how much room is left? Major modifications to the body? Recommend for a tranny?
Old 08-27-2007, 11:59 PM
Moppie's Avatar
Moppie Moppie is offline
Master Connector
Re: 454 in chevette?
Originally Posted by low1971
and what would you recommend for a tranny?
The Thai ones are pretty good.
Old 08-28-2007, 12:12 AM
'97ventureowner's Avatar
'97ventureowner '97ventureowner is offline
Re: 454 in a Chevette?
Please post our question in one forum only. Do not post it in multiple forums. Choose which forum you think would get the best responses.
Thought for the Day… Alcohol does not make you fat - It makes you lean... against tables, chairs, floors, walls and ugly people.
If a prostitute here in America loses her job to a prostitute in India , is that considered "outwhoring"??-Jay Leno
" A Good Thing To Know"
Old 08-28-2007, 06:00 AM
curtis73's Avatar
curtis73 curtis73 is offline
Professional Ninja Killer
Major firewall and transmission tunnel modifications will be necessary. Hot Rod or Car Craft did a similar thing with a Caddy 500 which is only slightly larger than a 454 and they had to basically cut everything out and sit with their knees laying on the bellhousing. I would lean toward a TH350 simply because its smaller and might require less surgery. As long as the 454 isn't too torquey the light weight of the car will make it very reliable.
You'll have to do something about the 6.5" rear axle. It sometimes blew up behind the stock 90-hp 4-banger.
Dragging people kicking and screaming into the enlightenment.
Old 08-28-2007, 10:59 AM
hotrod_chevyz's Avatar
hotrod_chevyz hotrod_chevyz is offline
I had an old mag article where 454/chevette were together. I thought they did a horrible job, dude didnt even have a place to sit.
If i were to attempt something like this, i would start out with a middle 80's s-10 short bed frame. Cut it down farther to match the length of the chevette, build it to handle a big block, and use the chevette "skin" to finish it up. Room wouldnt be a problem as long as you use some strategy when placing the chevette body on the frame. Weld up places to mount the body to the frame and if you get the body off the ground another foot or so, you could just about hide the frame ect with a body kit for a similar sized car.
Old 08-29-2007, 08:57 PM
Black Lotus's Avatar
Black Lotus Black Lotus is offline
Hahaha!
(not that I know anything about Katooeys, mind you.....)
Old 09-06-2007, 04:21 PM
chevy291 chevy291 is offline
I'm one of the guys in on the project would a 2 speed power glide bolt to the back of this motor the engine is a 77 and if not where would i find adaptor kits in vancouver
