Go Back   Automotive Forums Car Chat > Honda > Del Sol
Old 08-27-2007, 12:13 AM
5pt0 5pt0 is offline
wierd wired?!?
I just got a del Sol S on tuesday for $1500. But its got a few probs. The ICM just went out and my radiator needs to be replaced. Also the blower fan isnt working.
When I replace one of the underdash fuses, all of the running lights turn on. Any suggestions where I should start? thanks in advance guys!
Old 08-28-2007, 05:18 PM
AudioGuy93DelSol's Avatar
AudioGuy93DelSol AudioGuy93DelSol is offline
NA is Best!
Send a message via AIM to AudioGuy93DelSol
Re: wierd wired?!?
I don't know what you're asking. I can help you with the blower not working though. Take out your glove box and look at the black box. There should be a plug with 2 screws holding it into the box. Take the screws off and look at the underside. I'll have 2 wires running across and one or both of them has probably broken. Just pinch them back together.
Oil leak? What oil leak? That puddle under the car is just sweat from all that horsepower.
"How many NASCAR passes is that worth? 500?" (Schumacher passing Raikkonen)
Emily is amazing, and she messed with my sig AGAIN!
Old 08-28-2007, 06:06 PM
Re: wierd wired?!?
wow. i just read it and Im sorry for not making any sense at all.
What I meant to say was that there is a fuse that was missing underhood(my bad). Once I replaced it, (7.5A) the driving lights all turned on and would stay on. My radio started working too!
Old 08-28-2007, 06:20 PM
NA is Best!
Re: wierd wired?!?
Oh, so you're just saying you fixed a problem. Got it.
Old 08-29-2007, 04:21 PM
Re: wierd wired?!?
Let me try this again (Im soo busy building rockets) The corner lights are all staying on. I unplugged the switch at the steering column but lights are staying on. What do I need to do/check to make sure these lights are not staying on and draining my battery? Thanks guys.
