Old 11-16-2002, 04:08 PM
Dx18704 Dx18704 is offline
Send a message via AIM to Dx18704
Ecu??
What would happen if i have an automatic and get a manual ecu?
Old 11-16-2002, 04:20 PM
amy@af's Avatar
amy@af amy@af is offline
Traffic Directing Admin
Send a message via Skype™ to amy@af
it won't work. you need to keep AT ecu with AT and MT with MT
"hi! my name is Lady, and i'm a HONDA-holic"
..don't make me send Setanta over in his Waambulance to give you an aloe tissue for your sensitive nose!
*~ ~> USeR GUiDELiNeS*<~ ~*
I <3 the G Ride ~*~ I <3 OLD SKooL
Old 11-16-2002, 04:25 PM
ok thanx soo much......the 89 teg ecu will work for the mpfi swap to correct
kris's Avatar
kris kris is offline
Off playing with fire.
Hey, I have a AT ECU from a 89 Integra, which should work for your MPFI swap, if you want it.
Can anyone verify that? I know the teg ECU works, but will the AT option be the same?
Old 11-17-2002, 02:02 PM
Fishcat37's Avatar
Fishcat37 Fishcat37 is offline
Send a message via AIM to Fishcat37
If you have an automatic car, and use a MT ECU, then your transmission would not know when to shift (among other things). I'd bet that the car would start, but if you tried to drive around, it would be stuck in 1st gear
FLINT BLACK 1990 CRX SI
Appearance Mods:
-JDM EF8 CR-X SiR Spoiler
-94/95 Integra GS-R rims
Performance Mods:
-JDM B18C swap
-OBD1 conversion
-Chipped P28 ECU
-Skunk2 Intake Manifold
-DC Sports 4-2-1 Header
-MSD SCI-L ignition
-EXEDY Racing Clutch
Interior Mod
-'95 Integra GS-R Gauge Cluster
Former Motors - RIP:
-JDM B16A #1- Blew up due to over-revving
-JDM B16A #2 - Hydrolocked
Former Cars
'89 CRX Si - "The Bumblebee"
'94 Integra GS-R
'96 Camaro
ecu ecu ecu i see you MODIFIED_GSR Integra 7 05-04-2005 09:31 PM
converting ecu plugs to OBD-1 ???? p08 ecu install SIvic '88 - '91 Civic | CRX | Wagon | Shuttlee 2 03-21-2003 12:28 PM
88 ls ecu vs 89 ls ecu outofstep '71-'87 Civic | CRX 5 04-13-2002 01:41 PM
99 G20 ECU vs 98 Primera ECU bafo Engine 2 01-29-2002 01:29 PM
