Go Back   Automotive Forums Car Chat > Toyota > 4Runner/GX470
Old 08-19-2007, 10:37 PM
vandok13's Avatar
vandok13 vandok13 is offline
Brakes
I feel pretty retarted asking this but i cant get my drums off the rear brakes, is there a special way of doing it? with my f250 they just came right off with a little nock of a hammer. Toyotas are truly a hole different species of truck. Its a 1988 4runner automatic?any help much apprectiated
Old 08-21-2007, 05:46 PM
Brian R.'s Avatar
Brian R. Brian R. is offline
Resident Chemist
Send a message via Yahoo to Brian R.
Re: Brakes
If you already backed off the adjusting star wheel, just hit it harder at various points - from the back. It will come loose.
Forum Guidelines:http://www.automotiveforums.com/vbulletin/guidelines.html
"What we've got here is a failure to communicate"
Old 08-22-2007, 10:59 AM
fourwd1's Avatar
fourwd1 fourwd1 is offline
AF -Advisor
Re: Brakes
Keep hammering, also spray penetrant around lugs and center hub.
Also, there are 2 threaded holes, between lugs and opposite each other, for screwing in 8 or 10 mm bolts (can't recall) to force the drum off.
84 4Runner - ARBed 5.29s F&R, 4.7 & 2.28 t-cases, Chevys, AP x-over, BudBuilt x-member, 2" drv trn lift, 36" TSLs, 30 spline Longs
80 something p/u - Buick 231 V6/TH-350 trans, Holley 4 bbl, Weiand intake, dual batts, dual tanks ...
89 4Runner - stock
2000 Isuzu Trooper + 2010 Sonata
Old 08-22-2007, 03:17 PM
Brian R.'s Avatar
Resident Chemist
Re: Brakes
Actually, I don't think that model had the threaded holes, but I might be wrong....
If I remember correctly, they only put those holes in the disc brakes rotors since you can't beat on the rotors the same way you can beat on drums.
Old 08-23-2007, 11:24 AM
fourwd1's Avatar
AF -Advisor
Re: Brakes
I don't think you're remembering correctly.
89 4Runner - stock
Old 08-23-2007, 12:22 PM
Brian R.'s Avatar
Resident Chemist
Re: Brakes
