Old 11-16-2002, 03:19 AM
worrdogg worrdogg is offline
Unhappy HELP B16A Engine Problem!!!!!!!!!!!
I just did a JDM B16A swap in my 89 Civic sedan and ran into a problem. Here goes - When I drive around all day the engine runs fine but when I drive home from town on the highway at about 60mph the engine lags, and during the lag when I press the gas pedal nothing happens all it does is open the throttle and I can hear it but it the engine will not rev any higher. Now when I put it in neutral (still on the highway rolling at about 50mph) the engine shuts off. I then pull on the side of the highway and try to start it but it wont start. But when I wait a minute or so and try again it starts up and I drive off for about 10-15 minutes and it starts doing it again, and this keeps happening over and over. But here’s the funny thing, sometimes when the engine lags, I keep pressing the gas pedal and sometimes the engine kicks in and I can drive off till the next engine lag. What the heck is wrong? PLEASE ANYONE HELP!!!!!!!!!!!!
Old 11-16-2002, 03:46 AM
pvang31019 pvang31019 is offline
first I would like to add that run-on setences are not cool.
MY vote is an ignition problem...how was your wiring?
Old 11-16-2002, 10:18 AM
Frostbyte Frostbyte is offline
Send a message via ICQ to Frostbyte
Do you have a check engine light on? Also did you wire up your VTEC correctly?
1989 s13 Fastback
Tein HE coil-overs
sr20det swapped!
JIC Magic Front and Rear Strut Bars
Slotted and Cross-drilled Rotors
S/S Brake Lines
Pivot Lazy eye controller
Blitz LM Intake
Blitz D1 Spec Turbo Timer
Soon to come:
Sard 550cc Injectors
Blitz Nur Spec Exhaust
Blitz Down pipe
HKS FMIC
http://www.driftmonkey.com (Part Owner)
Old 11-16-2002, 12:59 PM
The check engine light does not come on. There are no codes appearing on the ECU. An expert installed it for me.
Old 11-16-2002, 03:38 PM
b16a3sol b16a3sol is offline
i wouldnt quite call him an expert ...
when it is dead, can you check for any problems like spark or fuel? does your car work fine all the time, or does it just experience problems after its been running for a while? can you rev it to redline any other time? give us some background info and maybe someone will have an answer.
Originally posted by honda720
i would never drive like that thats the pussy way to drive stick
Old 11-16-2002, 09:12 PM
Ive noticed that it seems like the problem happens after its been running for a while. Redlining is not a problem. I have a mugen spec chip installed if that might help. The engine runs fine.
Old 11-17-2002, 06:10 AM
civickiller civickiller is offline
Send a message via AIM to civickiller
i say try and swap ecus with a stock one and see if it still happens
also when was the last time you did a major tune up
Old 11-17-2002, 10:02 PM
take a look at your cat too. it could be that its pretty much clogged shut with stuff, inhibitting exhaust flow, making it only noticeable when it heats up and expands shut.
HELP B16A Engine Problem!!!!! worrdogg Engineering/ Technical 4 02-14-2007 12:19 PM
2002 Accord 4 CYL New Owner Needs Help with Engine Problem (Stalling and Maint. Light ncpmedic Accord/TSX/Accord Hybrid 4 10-18-2005 05:35 PM
need help with engine problem emopunksucksnuts Engineering/ Technical 2 10-19-2004 03:15 PM
Help with engine problem and getting codes 97GeoGirl Metro 16 03-08-2004 04:13 PM
Need Help With Engine Problem!!!! worrdogg '88 - '91 Civic | CRX | Wagon | Shuttlee 1 11-16-2002 03:26 AM
