Old 04-14-2004, 07:20 PM
drewk420 drewk420 is offline
Question need help with engine light problem
1991 honda civic dx My check engine light comes on and cause my car to run at a max of 3500 rpm. think it might be a mass airflow problem. I rigged the air box up so that it was getting direct air from the engine compartment. stupid sound trick. But i'm installing a new intake now and wanted to know if i need to reset the ecu after doing so that i dont have a mass air flow problem
Old 04-14-2004, 07:25 PM
travagliante's Avatar
travagliante travagliante is offline
Re: need help with engine light problem
mmmm. sounds simmilar to my problem,
crank angle sensor.
Heres how to diagnose to see the problem.
1. Pull the carpet on the pass left side to reveal the ecu.
2. Turn your key on but dont start car
3. Count the number of flashes.
If you count 4 the crank angle sensor went bad, meaning you need to get a new distributor, or you knocked a wire lose when installing intake.
Old 04-14-2004, 08:20 PM
what about a mass air flow issue with the inatake change do i need to do anything with that
Old 04-14-2004, 11:17 PM
Check the ecu first, how many lights flash in a sequence how many short flashes until a pause.
Old 04-15-2004, 03:26 PM
91civichatch2571's Avatar
91civichatch2571 91civichatch2571 is offline
Send a message via AIM to 91civichatch2571
Yea, like he said, pull your carpet back from the passenfer side floor where their feet would be. There will be a goldish plate with a whole in it. Turn your key to the on position, the LED in the whole will flash once to show that its getting power. If it flashes any after that, count how many times it flashes without pausing. This actually tells you exactly what is wrong with the car if anything. When you find out how many times its flashing, come back to us and we'll help you right out.
ZC stuff
http://dh-racing.com
http://www.thezcr.com/html/zcbook.php
http://dmoore.com/crx/zc.htm
http://www.jgenginedynamics.com/HOME%20PAGE
http://www.theoldone.com/
Old 04-15-2004, 05:34 PM
Hilikus Funkin's Avatar
Hilikus Funkin Hilikus Funkin is offline
Send a message via AIM to Hilikus Funkin
Our cars dont have mass air flow sensors dude, listen to what theyre saying.
1991 Honda Civic DX Sedan
Need Help with engine light, sensor problem dtrixny Quest | Presage | Serena 8 08-14-2008 05:54 AM
2002 Accord 4 CYL New Owner Needs Help with Engine Problem (Stalling and Maint. Light ncpmedic Accord/TSX/Accord Hybrid 4 10-18-2005 05:35 PM
need help with interior light problem 99 GXE drivera1 Altima 0 02-10-2004 05:28 PM
Need Help With A Lighting Problem sp3cial_bl3nd Exterior | bodykits | Lighting 11 09-05-2003 02:52 AM
Need Help With A Lighting Problem sp3cial_bl3nd Accord/TSX/Accord Hybrid 3 07-29-2003 03:41 PM
