Old 08-08-2007, 02:40 PM
frag_angel frag_angel is offline
Send a message via MSN to frag_angel
Nissan 300ZX WIP
this is my first car have done 2 ore 3 before but i thinking of get serious whit this one what is putting and where can i find it iam from sweden need a little help
Shot with FinePix A500 at 2007-08-08
an one question more aa how do i easiest cut in the glass material ? want to get rid of the side and top window so i can go targa :P hehe
like my dad said to me when i hurt my self ore scrued it up if it don't kill you it make you stronger
Old 08-08-2007, 07:42 PM
rsxse240 rsxse240 is offline
Re: Nissan 300ZX WIP
I would suggest referring to a real car to see where the glass is supposed to be, or rather, where it shouldn't be if the windows are open, then go from there. I used to own a twin turbo Z (similar to that one) and when the side glass is down, the door frame extends up to the roof line and has a slot that an alignment pin from the glass slides in to keep the glass straight with the door. it SHOULDN'T be that difficult to reproduce. Now for the roof, I'd suggest just cutting the "glass right where it has the notch for the windshield frame, and CAREFULLY cutting the "T" top frame out, as well as the piece that connects the A pillar to the B pillar. then just glue those parts to the leftover glass from the T-Tops, and put them in the trunk.
Old 08-09-2007, 01:41 AM
MidMazar's Avatar
MidMazar MidMazar is offline
Using a pe saw works, or you can drill a tiny hole in the window where you want to cut it and put in a small piece of thread (yarn) and pull on it back and forth. What that does is it basically melts the plastic leaving a flawless edge. I think there is a tutorial here, if not search for it.
In Progress
Old 08-09-2007, 01:42 AM
Captain Mark's Avatar
Captain Mark Captain Mark is offline
Here's a pic of my Z in the bottom corner, and a friend's Z on the driveway (both with windows down). Not the best shot but it's all I have with me at work - hopefully it'll give you an idea of where to cut the window.
For cutting I'd personally use a scribing blade. I've never tried the thread method mentioned above, but it sounds interesting.
Old 08-09-2007, 11:18 AM
thank you guys i am taking that in consideration i was down to the chop an bought some epoxy and some plastic "sheet" :P its not gonna be original
Old 08-09-2007, 04:17 PM
this is what i made to day
Shot with FinePix A500 at 2007-08-09
Old 08-09-2007, 06:26 PM
Ferrari TR's Avatar
Ferrari TR Ferrari TR is offline
Not A Hoarder!
That's quite the wide body.
SCCA 7, The lost Z
Old 08-09-2007, 06:40 PM
thats what i was thinking about have more things to it :P post that tomorow when i come home from work
Old 08-10-2007, 05:52 PM
i have to much spare time :P ore i take much time :P this is what i'w done tonight:P
Shot with FinePix A500 at 2007-08-10
some differ ens :P
Old 08-11-2007, 01:06 AM
Enzoenvy1's Avatar
Um, wow, that is going to be one sturdy model there! I am curious of what it will look like now.
Old 08-11-2007, 01:17 PM
mm iam not that good at anything of this but i am trying as good as i can to get my thoughts down to the body hopefully i get what i am searching for :P
Old 08-11-2007, 03:50 PM
Dying Fetus's Avatar
Dying Fetus Dying Fetus is offline
This should be an interesting build. I have 2 concerns though:
1. You completely removed the front bumper, hopefully this isn't going to give you trouble with assembly.
2. Looks as though you puttied the hood to the body, any plans to have an opening hood?
Keep up the good work!!!
Current Model Projects:
Peugeot 206, Toyota Supra, Honda NSX, Toyota Celica, Honda S2000, Toyota MR2, & many others.
Old 08-11-2007, 05:39 PM
yes thats already taken care of yes i know that its risky taking the front bumper of the chassi has its mountings there but i figure that out some i think
http://img167.imageshack.us/img167/7554/dscf2701hu6.jpg
Shot with FinePix A500 at 2007-08-11
Last edited by Jay!; 08-16-2007 at 08:51 PM. Reason: Careful about your backgrounds. This is supposed to be a 13+ friendly forum.
Old 08-16-2007, 08:14 PM
i was down at the lokal hobby shop to day :P
Shot with FinePix A500 at 2007-08-16
this is what i made so far
Shot with FinePix A500 at 2007-08-17
c&C are welcome say what you think its my first build so i want to here what i can do better
Old 08-16-2007, 11:56 PM
I'm just wondering what kind of putty you are using that you keep changing the body kit, without messing up the body.
the body kit looks alright, but just needs some refinement, and definition. I can feel where you are going with the front bumper, it's just not a route I'd normally see here on A/F
